Viewing 15 posts - 1,741 through 1,755 (of 6,391 total)
  • in reply to: rapidscada 6.1 install on linux problem #13014
    ScadaAdmin for Wine is here. May be it’s not the latest, anyway it should start.
    1. Install Wine according to https://wiki.winehq.org/Ubuntu
    winehq-staging is needed
    2. Run winecfg
    3. Check Wine version wine --version
    4. Change directory to the app directory. Run wine ScadaAdmin.exe
    5. Check ScadaAdmin logs in /home/myuser/.wine/drive_c/users/myuser/AppData/Local/
    Does it work?
    in reply to: rapidscada 6.1 install on linux problem #13011
    If you need to run Admin with Wine, ask for special instructions.
    in reply to: Running in Raspberry Pi #13008
    2023-07-14 11:45:28 [RapidScada][root][ACT] The configuration database has been received successfully
    2023-07-14 11:45:29 [RapidScada][root][INF] The application is ready for operating
    That means that the web app works correctly.
    What URL do you use to open it in browser?
    in reply to: Running in Raspberry Pi #13005
    > the raspberry pi 3b and the os is raspberry pi os (32-bit)
    It is slower than RPi4. You can see in the log that the start of SCADA-Server takes about 1 minute.
    Also ScadaWeb.log is needed.
    • This reply was modified 3 years, 3 months ago by Mikhail.
    in reply to: Running in Raspberry Pi #13001
    ScadaServer.log and ScadaComm.log are OK.
    Which Raspberry version do you use?
    in reply to: Copy and paste notifications #12998
    You should use a good XML editor that can collapse and expand nodes, so you can check that the XML structure is correct. Otherwise, move to v6. We can update license keys for the new version.
    in reply to: Running in Raspberry Pi #12997
    What is written in ScadaServer.log and ScadaWeb.log?
    in reply to: Copy and paste notifications #12994
    For example
    C:\SCADA\Projects\HelloWorld\Instances\Default\ScadaServer\Config\ModAutoControl.xml
    in reply to: Running in Raspberry Pi #12993
    Could you provide a screenshot of the error?
    in reply to: Elastic Plugin exports PDF garbled characters #12992
    Does the PDF of this version still not support Chinese fonts?
    Elastic Report 6.0.0.0 cannot load fonts, so it does not support Chinese fonts.
    The described method will work with a new Elastic Report version which is expected in August.
    in reply to: Elastic Plugin exports PDF garbled characters #12988
    The issue will be fixed in the next Elastic Report release. Thank you for reporting.
    You will need to:
    1. Install a font that supports Chinese, like arialuni.ttf. On Windows, the font must be installed for all users into C:\Windows\Fonts
    2. Specify the font name in SCADA\ScadaWeb\wwwroot\plugins\ElasticReport\templates\PdfStyleDefault.xml
    For example, ArialUni
    in reply to: Copy and paste notifications #12986
    Copy and Paste buttons were added in the 6th version of the module.
    In the 5th version, you could try editing the ModAutoControl.xml file by an external XML editor like Notepad++.
    in reply to: How many bit in DWORD and WORD #12984
    in reply to: Elastic Plugin exports PDF garbled characters #12982
    – Operating system version
    – Elastic Report Plugin version
    in reply to: How to set up Telegram #12981
    Please provide a link to a screenshot of the device settings in Communicator.
