RapidVZ
Participanthttps://drive.google.com/file/d/18AX-5VUHqc8CAvjOWB43jFGLUQ-Ycuhg/view?usp=drivesdk
This manual is the tbr 1000
RapidVZ
ParticipantThe operating system is Windows 11 x64 and the equipment is Toshiba TB-R1000.
RapidVZ
ParticipantAnd is there a guide to do it with the opc server
RapidVZ
Participanteliminate please..
error post
RapidVZ
Participantthanks…
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][ACT] Server 6.2.0.1 started
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\FileStorage.dll
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][ACT] Start logic processing
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][ACT] The configuration database has been read successfully
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][INF] Number of active channels for archiving: 6
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][INF] Number of active channels for sending commands: 0
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][ACT] Compile the source code of scripts and formulas
2024-10-14 09:51:24 [VICTORIO][VICTORIO$][ACT] Added the following dependencies:
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\netstandard.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\System.ComponentModel.Primitives.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\System.Console.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\System.Diagnostics.Process.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\System.Linq.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\System.Private.CoreLib.dll
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.10\System.Runtime.dll
C:\Program Files\SCADA\ScadaServer\ScadaCommon.dll
C:\Program Files\SCADA\ScadaServer\ScadaServerEngine.dll
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] The source code of scripts and formulas has been compiled successfully
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Module ModArcBasic 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcBasic.Logic.dll
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Module ModArcPostgreSql 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaServer\Mod\ModArcPostgreSql.Logic.dll
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Archive Cur initialized successfully
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Archive Min initialized successfully
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Archive Hour initialized successfully
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Archive Events initialized successfully
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Start listener on port 10000
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][INF] Archive in DAT format: C:\Program Files\SCADA\Archive
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][INF] Archive copy in DAT format: C:\Program Files\SCADA\ArchiveCopy
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Delete outdated data from the Min archive older than 15/10/2023
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Delete outdated data from the Hour archive older than 15/10/2023
2024-10-14 09:51:26 [VICTORIO][VICTORIO$][ACT] Delete outdated data from the Events archive older than 15/10/2023
2024-10-14 09:51:29 [VICTORIO][VICTORIO$][ACT] Session with ID 919218508979413905 created
2024-10-14 09:51:29 [VICTORIO][VICTORIO$][ACT] Client 127.0.0.1 connected
2024-10-14 09:51:29 [VICTORIO][VICTORIO$][ACT] User ScadaComm is successfully authenticated
2024-10-14 09:51:31 [VICTORIO][VICTORIO$][ACT] Client 127.0.0.1 disconnected
2024-10-14 09:51:31 [VICTORIO][VICTORIO$][ACT] Session with ID -780509678390661647 created
2024-10-14 09:51:31 [VICTORIO][VICTORIO$][ACT] Client 127.0.0.1 connected
2024-10-14 09:51:31 [VICTORIO][VICTORIO$][ACT] User ScadaComm is successfully authenticatedweb:
2024-10-14 07:53:19 [VICTORIO][Usuario][ACT] Receive the configuration database
2024-10-14 07:53:19 [VICTORIO][Usuario][ERR] Error checking server connection:
Incorrect format of data received from the server: data length is too big -
