redass
Participant@Mikhail
Exactly, the simplest way would be if there was such a function when adding a button with the send command now option immediately with a given value (somewhere nearby). The next one is the same button but a different value (111e, 1122, 113d) each button for a different value.redass
Participantjust the value 111e in the popup
redass
Participant111e circuit activation
1122 circuit tripredass
ParticipantSince I’m a beginner, what should I do step by step? Where to enter which formula? I’ll write it down. At this moment, when I turn it on using the button connected to channel no. 1031, the console to enter the value starts and this is how it works at the moment. I want the button (or even different buttons to send different commands) and when the button is turned on, the circuit sends the 111e command. When I click the second button, I want it to send the command 1122. How and where exactly should I set this?
redass
Participantso I would like to create several buttons with different commands. What formula to use for example. connect the circuit with command 111e or turn off the circuit with command 1122
Is it enough to enter a channel with a given value in output?redass
ParticipantHello, I would like it to send the value immediately (without entering the command) when the button is clicked. This value is e.g. 111e. Does it need to be entered in the formula or is there a function somewhere?
redass
ParticipantThe easiest way is because I’m a beginner. I have a formula (Cnl%256)/100 and it calculates correctly and the device throwing the value 2.55 is considered 0 or null(invalid) and I want to get such an entry when it enters such a value.
redass
Participanthowever, when I try to connect to this converter, an error occurs
(Cnl%256)/100 -
