hendra_allo
Participant024-07-05 22:12:22 [hendra-ThinkPad-X220][root][ACT] Webstation is stopped
2024-07-05 22:12:32 [hendra-ThinkPad-X220][root][ACT] Webstation 6.2.0.1 started
2024-07-05 22:12:32 [hendra-ThinkPad-X220][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaWeb/FileStorage.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgChart 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgChart.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgMain 6.0.3.1 loaded from file /opt/scada/ScadaWeb/PlgMain.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgScheme 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgScheme.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgSchBasicComp 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgSchBasicComp.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgStore 6.0.0.0 loaded from file /opt/scada/ScadaWeb/PlgStore.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgWebPage 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgWebPage.dll
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] Receive the configuration database
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ACT] The configuration database has been received successfully
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][INF] The application is ready for operating
2024-07-05 22:12:33 [hendra-ThinkPad-X220][root][ERR] Web host failed to start:
System.IO.IOException: Failed to bind to address http://0.0.0.0:10008: address already in use.
—> Microsoft.AspNetCore.Connections.AddressInUseException: Address already in use
—> System.Net.Sockets.SocketException (98): Address already in use
at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, Boolean disconnectOnFailure, String callerName)
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportOptions.CreateDefaultBoundListenSocket(EndPoint endpoint)
at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketConnectionListener.Bind()
at Microsoft.AspNetCore.Server.Kestrel.Transport.Sockets.SocketTransportFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken)
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Infrastructure.TransportManager.BindAsync(EndPoint endPoint, ConnectionDelegate connectionDelegate, EndpointConfig endpointConfig, CancellationToken cancellationToken)
at Microsoft.AspNetCore.Server.Kestrel.Core.KestrelServerImpl.<>c__DisplayClass28_0`1.<<StartAsync>g__OnBind|0>d.MoveNext()
— End of stack trace from previous location —
at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.AddressBinder.BindEndpointAsync(ListenOptions endpoint, AddressBindContext context, CancellationToken cancellationToken)
@hendra_allo
Participanthi Mikhail, I just sorted out the issue by observing file /var/log/scada/ScadaWeb/log/ScadaWeb.log, it said the address 0.0.0.0:10008 already used. Then I run
sudo lsof -i tcp:10008
and I found it was used by php. Then I killed the php process, and now ScadaWeb is running well and I can access rapidscada via the browser. Thanks for your help.
hendra_allo
ParticipantWhen I open http://localhost:10008, now comes the message “The connection was reset”. Still can’t open openscada interface yet.
hendra_allo
ParticipantScadaComm.log:
2024-06-28 22:03:31 [hendra-ThinkPad-X220][root][ACT] Communicator 6.2.0.0 started
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaComm/FileStorage.dll
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ACT] Start logic processing
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file /opt/scada/ScadaComm/Drv/DrvDsScadaServer.Logic.dll
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ACT] Driver DrvSimulator 6.0.0.0 loaded from file /opt/scada/ScadaComm/Drv/DrvSimulator.Logic.dll
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ACT] Data source ScadaServer initialized successfully
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ACT] Data source ScadaServer: Receive the configuration database
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ERR] Data source ScadaServer: Error checking server connection:
Connection refused [::ffff:127.0.0.1]:10000
2024-06-28 22:03:33 [hendra-ThinkPad-X220][root][ERR] Unable to start communication lines because the configuration database is not received
2024-06-28 22:03:43 [hendra-ThinkPad-X220][root][ACT] Data source ScadaServer: Receive the configuration database
2024-06-28 22:03:44 [hendra-ThinkPad-X220][root][ACT] Data source ScadaServer: The configuration database has been received successfully
2024-06-28 22:03:44 [hendra-ThinkPad-X220][root][ACT] Start communication lines
2024-06-28 22:03:44 [hendra-ThinkPad-X220][root][ACT] Start reading commands from files
2024-06-28 22:03:44 [hendra-ThinkPad-X220][root][ACT] Data source ScadaServer: Connection state is Logged Inhendra_allo
Participantnginx error log (last line)
2024/06/28 23:28:08 [error] 1235#1235: *14 recv() failed (104: Unknown error) while reading response header from upstream, client: 127.0.0.1, server: _, request: “GET /Scada/ HTTP/1.1”, upstream: “http://127.0.0.1:10008/Scada/”, host: “127.0.0.1”
hendra_allo
ParticipantSession with ID -7665733298275766740 created
2024-06-28 23:31:02 [hendra-ThinkPad-X220][root][ACT] Client 127.0.0.1 connected
2024-06-28 23:31:02 [hendra-ThinkPad-X220][root][ACT] User ScadaWeb is successfully authenticated
2024-06-28 23:31:04 [hendra-ThinkPad-X220][root][ACT] Client 127.0.0.1 disconnectedhendra_allo
ParticipantI have copied the file, still bad gateway appear
hendra_allo
Participantwhere is nginx default file located?
hendra_allo
Participant● nginx.service – A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset:>
Active: active (running) since Fri 2024-06-28 22:03:29 NZST; 13min ago
Docs: man:nginx(8)hendra_allo
Participantsorry, scadaweb6.service seems still doesn’t work
● scadaweb6.service – Rapid SCADA Webstation
Loaded: loaded (/etc/systemd/system/scadaweb6.service; enabled; vendor pre>
Active: activating (auto-restart) since Fri 2024-06-28 22:10:22 NZST; 2s a>
Process: 5152 ExecStart=/usr/bin/dotnet /opt/scada/ScadaWeb/ScadaWeb.dll –>
Main PID: 5152 (code=exited, status=0/SUCCESS)
CPU: 864mshendra_allo
Participantscada* daemon are now running, but dotnet version is 8.0.6 and 502 Bad Gateway still appear.
.NET SDKs installed:
No SDKs were found..NET runtimes installed:
Microsoft.AspNetCore.App 8.0.6 [/usr/share/dotnet/shared/Microsoft.AspNetCore.App]
Microsoft.NETCore.App 8.0.6 [/usr/share/dotnet/shared/Microsoft.NETCore.App]Other architectures found:
NoneEnvironment variables:
DOTNET_ROOT [/home/hendra/dotnet]global.json file:
Not foundLearn more:
https://aka.ms/dotnet/infoDownload .NET:
https://aka.ms/dotnet/download-
This reply was modified 2 years, 4 months ago by
hendra_allo.
hendra_allo
Participantglobal.json file:
Not foundHost:
Version: 6.0.31
Architecture: x64
Commit: e2ca2f8a1c.NET SDKs installed:
No runtimes were found.Download .NET:
https://aka.ms/dotnet-downloadLearn about .NET Runtimes and SDKs:
https://aka.ms/dotnet/runtimes-sdk-infohendra_allo
Participanthi all. Still relevant with this topic, I am facing the issue with 502 Bad Gateway of Nginx. It seems to me that scada* daemon can not start. Following the response when I check the scadaserver6.service status:
● scadaserver6.service – Rapid SCADA Server
Loaded: loaded (/etc/systemd/system/scadaserver6.service; enabled; vendor >
Active: activating (auto-restart) (Result: exit-code) since Fri 2024-06-28>
Process: 5198 ExecStart=/usr/bin/dotnet /opt/scada/ScadaServer/ScadaServerW>
Main PID: 5198 (code=exited, status=131)
CPU: 3msHow to fix this? Thanks
