Researcher
  • in reply to: Error uploading configuration #14547
    Researcher
    I installed the software on another computer, and I am no longer receiving the configuration error.
    Thank you for your help!
    in reply to: Error uploading configuration #14493
    Researcher
    Here are the results from running the dotnet command
    https://ibb.co/7CQ9b82
    in reply to: Error uploading configuration #14486
    Researcher
    No, I get the same error message when trying to upload the HelloWorld project.
    in reply to: Error uploading configuration #14475
    Researcher
    There are no files in the ScadaAgent/Temp directory.
    in reply to: Error uploading configuration #14470
    Researcher
    I received the error attempting to upload the configuration after creating a new file for a “Table View”. See screenshot https://ibb.co/9H3pT88
    The below is from the ScadaAgent.log. Is this the error? (changed my personal computer information to “MyComputer”.
    2024-04-25 15:48:56 [MyComputer][MyComputer][ACT] User ScadaAdmin is successfully authenticated
    2024-04-25 15:48:57 [MyComputer][MyComputer][ACT] Receive file [Agent]\[Temp]\upload_config_7361909534725472366.zip
    2024-04-25 15:48:57 [MyComputer][MyComputer][ERR] Error processing request 0x0104 for client 127.0.0.1:
    System.IO.FileNotFoundException:
    File name: 'System.IO.Compression, Version=8.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
       at Scada.Agent.Engine.ScadaInstance.UnpackConfig(String srcFileName)
       at Scada.Agent.Engine.AgentListener.ProcessFile(ConnectedClient client, RelativePath path, Object uploadContext)
       at Scada.Server.ListenerBase.UploadFile(ConnectedClient client, DataPacket request, ResponsePacket& response)
       at Scada.Agent.Engine.AgentListener.ProcessCustomRequest(ConnectedClient client, DataPacket request, ResponsePacket& response, Boolean& handled)
       at Scada.Server.ListenerBase.ProcessRequest(ConnectedClient client, DataPacket request)
    • This reply was modified 2 years, 5 months ago by Mikhail.
    in reply to: Error uploading configuration #14455
    Researcher
    I am receiving the follow error after creating a table folder/file and attempting to upload the configuration:
    https://ibb.co/9TRPcy4
