Viewing 1 post (of 1 total)
Tomasz
ParticipantHi.
I have Ubuntu.
ScadaWeb.log:024-02-09 09:35:13 [tomasz-Latitude-5480][root][ACT] Webstation 6.2.0.0 started 2024-02-09 09:35:13 [tomasz-Latitude-5480][root][ACT] Storage FileStorage 6.1.0.0 loaded from file /opt/scada/ScadaWeb/FileStora> 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgChart 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgChart.dll 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgMain 6.0.3.1 loaded from file /opt/scada/ScadaWeb/PlgMain.dll 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgScheme 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgScheme.dll 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgSchBasicComp 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgSch> 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgStore 6.0.0.0 loaded from file /opt/scada/ScadaWeb/PlgStore.dll 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgWebPage 6.0.2.0 loaded from file /opt/scada/ScadaWeb/PlgWebPage.> 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ACT] Receive the configuration database 2024-02-09 09:35:14 [tomasz-Latitude-5480][root][ERR] Error checking server connection: Connection refused [::ffff:127.0.0.1]:10000 2024-02-09 09:35:24 [tomasz-Latitude-5480][root][ACT] Receive the configuration database 2024-02-09 09:35:24 [tomasz-Latitude-5480][root][ACT] The configuration database has been received successfully 2024-02-09 09:35:24 [tomasz-Latitude-5480][root][INF] The application is ready for operating
This reply was modified 2 years, 9 months ago by
