yassor
  • yassor
    All 8 MPPT are connected to the single modbus host and provide different data.
    Each MPPT has different modbus address and ID in the host device. But all of them (8 MPPT) has unique register maps because it’s the same model.
    The conext has it’s modbus address 502 and lan address 192.168.1.100, and a unique register maps.
    Each MPPT has a different modbus address and ID in the Conext device.
    All MPPT has the same register maps beacause it’s same model.
    Here is a Screenshot of that : https://filetransfer.io/data-package/ayo8WWzO#link
    or
    https://file.io/hAQYuLfaVxv8
    yassor
    Hi Mikhail,
    i have the modbus register maps of the Conext device and i select these one for what i want to do, you can see it in hexadecimal or decimal here https://filetransfer.io/data-package/ayo8WWzO#link or here https://file.io/r9t4x6fIFTi9.
    But here is my problem, i have like 8 MPPT (solar power controler) plug into the device, each MPPT has a modbus addresse like 10 for MPPT 1, 11 for MPPT2, or 30 for MPPT8, in the device.
    And in the register maps of the device (conext), the MPPT register address has like 0x008C or 140 for the PV Power. How do i set the program to know that i want the PV power in the address of 140 of MPPT5 at modbus address of 15 for exemple ?
    i’m really sorry for my english ! Feel free to ask if you need to know more about this
    yassor
    Hi Mikhail,
    I’ll ask the manufacturer if they can provide me that and i’ll give you the result
    thank you for the help !!
    yassor
    Hi Mikhail, i stayed up all the night to find this, and it worked with a litle problem, or big :
    <DeviceTemplate>
    <Options>
    <ZeroAddr>false</ZeroAddr>
    <DecAddr>true</DecAddr>
    <DefByteOrder2 />
    <DefByteOrder4 />
    <DefByteOrder8 />
    </Options>
    <ElemGroups>
    <ElemGroup active=”true” dataBlock=”HoldingRegisters” address=”68″ name=”1″>
    <Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”100001″ name=”Output solar power” />
    </ElemGroup>
    <ElemGroup active=”true” dataBlock=”HoldingRegisters” address=”94″ name=”2″>
    <Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”100002″ name=”Output load (Sum XW)” />
    </ElemGroup>
    <ElemGroup active=”true” dataBlock=”HoldingRegisters” address=”98″ name=”3″>
    <Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”100003″ name=”Output load (Sum XW)” />
    </ElemGroup>
    <ElemGroup active=”true” dataBlock=”HoldingRegisters” address=”344″ name=”4″>
    <Elem type=”ushort” readOnly=”false” isBitMask=”false” tagCode=”100004″ name=”Batterie load/power” />
    </ElemGroup>
    </ElemGroups>
    <Cmds />
    </DeviceTemplate>
    is there any way to collecte or see the address of value in modbus device ? like here the Output of solar pannel is on address 344 and it took me many time to get it, and also somme has an incomprehensible value like 15 191. And my bigest problem now is that i don’t know whitch value correspond to voltage or current …
    yassor
    hi, i fixed some issue with the tag and create all of theme but some shows a weird value and some doesn’t show any value
    there are the screenshot of line log and device :
    https://drive.google.com/file/d/1qsKmiltGuPxQnrqmfATcl6txqFWdp6L0/view?usp=drive_link
    https://drive.google.com/file/d/1vgftUoH68BDcXAe9OLMOjcMDZPz4WPI6/view?usp=drive_link
    And also a xml code that i used to do the request : https://drive.google.com/file/d/1_wLKMYatgFaSsmYLhoo6L8jCY2aKVObD/view?usp=drive_link
    yassor
    Hi Mikhail, here is the update that i made (don’t be mad i’m a noob) :
    Line state :
    [1] Test line
    Status : Normal
    Communication channel : TCP client, connected
    Shared Data (1)
    Modbus.Templates = Dictionary of 1 templates
    Devices (1)
    [1] Test device : Normal
    Line Log :
    2023-10-31 15:52:50 Session with the device [1] Test device
    No elements to request
    2023-10-31 15:52:51 Session with the device [1] Test device
    and i use this template on LAN (the conext combox is the test device :
    <DeviceTemplate FormatVersion=”5″ Name=”ConextComBox” Descr=”Modbus and HTTP Device Template for Conext ComBox”>
    <Connection Required=”true” />
    <CommSettings>
    <!– Modbus TCP Connection –>
    <Connection Kind=”Tcp” Address=”192.168.1.100″ Port=”502″ />
    <!– HTTP Connection –>
    <Connection Kind=”Http” Address=”http://192.168.1.100 ” Port=”80″ />
    </CommSettings>
    <!– Define Data Channels for Modbus Communication –>
    <DataChannels>
    <!– Read Holding Registers Example for Voltage –>
    <DataChannel Name=”Voltage” DataType=”Float” Command=”MBReadHoldingRegisters” Address=”1″ Function=”3″ Offset=”100″ Quantity=”1″>
    <DeviceChannelID>1</DeviceChannelID>
    </DataChannel>
    <!– Read Holding Registers Example for Current –>
    <DataChannel Name=”Current” DataType=”Float” Command=”MBReadHoldingRegisters” Address=”1″ Function=”3″ Offset=”200″ Quantity=”1″>
    <DeviceChannelID>2</DeviceChannelID>
    </DataChannel>
    </DataChannels>
    <!– Define Data Channels for HTTP Communication –>
    <DataChannels>
    <!– HTTP Data Channel Example –>
    <DataChannel Name=”Status” DataType=”String” Command=”Http” Address=”/status”>
    <DeviceChannelID>3</DeviceChannelID>
    </DataChannel>
    </DataChannels>
    </DeviceTemplate>
    • This reply was modified 3 years ago by yassor.
    yassor
    is my device template okay ?
