XptoPT
Viewing 15 posts - 1 through 15 (of 15 total)
  • in reply to: How to write value and appear on the screen? #15815
    XptoPT
    Hello Mikhail,
    Thanks for the explanation, now I understand.
    Best regards.
    in reply to: How to write value and appear on the screen? #15778
    XptoPT
    Hello Mikhail,
    Changing the Data Length worked.
    “Note that the next 2 channels may not be sequential channel numbers.”
    I didn’t quite understand this note, please explain it to me in more detail.
    Thank you very much for your help.
    Best regards.
    in reply to: How to write value and appear on the screen? #15763
    XptoPT
    Hello Mikhail,
    I want to start by thanking you for your help.
    I have already tested and your code is working.
    But I need an improvement.
    The result only displays up to 4 characters.
    For example, if I type “asdfghjkl”, the result displayed is “asdf”.
    To make sure the customer has no limitations, can you please provide a code that accepts 50 characters?
    Best regards.
    in reply to: How to write value and appear on the screen? #15749
    XptoPT
    Hello Mikhail,
    Thanks for the quick response.
    I have no experience using Rapid Scada, I need a more detailed explanation.
    Where should I post the code you wrote?
    How should I configure the other channel parameters (e.g. Data Type, Input and output formula, format, command format)?
    Thank you very much for your help and patience.
    in reply to: How to write value and appear on the screen? #15729
    XptoPT
    Hello Mikhail,
    Is there a formula like SetData() that can be used for text (string)?
    I need to create dynamic text so that the operator can edit the text whenever necessary.
    I’m using V6.
    Thanks for the help.
    Best regards.
    • This reply was modified 1 year, 10 months ago by XptoPT. Reason: Add additional information
    in reply to: Login Page #13824
    XptoPT
    Perfect, Shift + F5 worked.
    Thank you very much!
    in reply to: Login Page #13814
    XptoPT
    I have already replaced the “gear” image with a new image, I gave the new image the same name as “gear”, but the old image continues to appear on the login page.
    Can you help me?
    Thanks.
    in reply to: V5 and V6 installation #13745
    XptoPT
    Thanks, I’ll test it.
    in reply to: V5 and V6 installation #13732
    XptoPT
    Can I choose any port number, or do you have any suggestions?
    Thanks.
    in reply to: V5 and V6 installation #13717
    XptoPT
    I had to do some tests.
    By managing the activation of services for each version, I can have each version working individually.
    But I’m not able to have the 2 versions working simultaneously, can you please explain in more detail where I should configure the TCP ports?
    Where should I have different TCP ports? In my project “General settings” or in the project upload settings?
    Thank you for your help.
    in reply to: Modify table XML “Minute data report” #13699
    XptoPT
    Thank you, I already discovered the problem.
    in reply to: Modify table XML “Minute data report” #13639
    XptoPT
    It’s a new project that I’m creating.
    Yes, I am logged in as “admin”.
    “Make sure that an object exists in the Objects table, and channel’s object is not empty.”
    Yes, I believe everything is correct.
    in reply to: Modify table XML “Minute data report” #13631
    XptoPT
    Good morning,
    Considering your instructions, I am already working on version 6.
    Screenshot:
    https://ibb.co/vQcC4g0
    I can’t select any object to download the report.
    What configuration might be missing?
    Thanks.
    in reply to: Modify table XML “Minute data report” #13630
    XptoPT
    Good morning,
    “The report template was updated in v6. You could check it.”
    In version Rapid SCADA 6.x, “Report” in the “Minute data report” function appears the “Time” column in all lines?
    Thanks.
    in reply to: Modify table XML “Minute data report” #13612
    XptoPT
    Good morning,
    I use version 5.8.4.
    I would like to take this opportunity to ask a new question, for new client projects, is it a good option to use this version?
    Or for new projects should we use version 6.1.5?
    I ask this question to find out if version 5 will continue to be updated or if for new projects we have to use version 6.
    Thanks.
