anaisthrl
ParticipantThank you for your answer.
Do you know if it is possible to access the data history to modify it?
anaisthrl
ParticipantAdd the notion of “condition” on the following properties of a schema editor object: Background color, text, visibility, width, height.
Background color
Text content
Visible / Invisible
Width
Height
blinking (even slow/fast option, but less critical)
bar graphUses:
-Color of an LED or of a text background according to the value of a word. In red if word value = 1, in green if =2 etc…
-How to make the text appear according to the value of a word. This works for an output channel (with values commands).
Example: if word value =0, write AUTO in the dynamic text, if =1, write MANU etc…-How to create a visibility condition of an object relative to the value of an input channel
-Bar-graph objects with interior filling according to the value of a word and its mini and maxi.
anaisthrl
ParticipantDWORD corresponds to a double ? So double has 32 bit ?
anaisthrl
ParticipantHello, thank you for your answer.
I tried to attach to the process w3wp.exe, but it doesn’t appear in the processes list. I saw in a forum that it is supposed to show only after a first access to the web page, but didn’t change anything for me.
Do you have another track or an idea on something I’m doing wrong ?
June 28, 2023 at 1:29 pm in reply to: Add channel name in Input/Ouput channel parameters in Scada Scheme #12895anaisthrl
ParticipantHello,
For the moment, we can’t enter channel number manually. The user choose an channel in the data grid view and the number of channel is wrote between ().
But, if you prefere, we can adapt the code to show the channel number before the name . Like (number) name.
This reply was modified 3 years, 3 months ago by
anaisthrl.
June 28, 2023 at 7:00 am in reply to: Add channel name in Input/Ouput channel parameters in Scada Scheme #12886anaisthrl
ParticipantHello,
Yes sure.You will find the images here:
https://ibb.co/wQv3yS9
https://ibb.co/V293r1t
https://ibb.co/7zhHVncJune 8, 2023 at 1:08 pm in reply to: Retrieve the channels and devices list from Scada Scheme Editor V5 #12776anaisthrl
ParticipantDo you know the reference that allows me to access the project folder of Scada Admin to retrieve the XML files ?
June 8, 2023 at 11:38 am in reply to: Retrieve the channels and devices list from Scada Scheme Editor V5 #12775anaisthrl
ParticipantHello,
Thanks a lot for your help !
June 7, 2023 at 12:04 pm in reply to: Retrieve the channels and devices list from Scada Scheme Editor V5 #12773anaisthrl
ParticipantHello,
I try to customize the Scada Scheme of Rapid Scada 5, so it doesn’t matter if it doesn’t work with Rapid SCADA 6.
Yes, it would be great, I would like display channels in a new property of th editor.
