asherb
Participanthello Mikhail,
I am wondering how long would take this to develop? on the other hand, is there any formula, or leeway we can sort of achieving this? because this is very critical for us.
thanks
asherb
thank you for the help. Right now we can get all letter in, but the order is not right and no orders. the correct string should be: ‘1.Vertical Nail Both’, however, we got this: https://sm.ms/image/xAlPIzpXKNWqDwm (with byte order: 44012367)
we tried change byte order, however, we are not able to get the right byte order. would this be related to the script of Strings? can you help us to figure this out?
our current setup:
https://sm.ms/image/pNVc9oYsitZ5Sa7
https://sm.ms/image/j89WeTUDXPOqyHCthanks!
asherb
when i have your setup, the server goes down and it shows me this error:https://sm.ms/image/RLVTirJ5gjeIdHf
my setup: https://sm.ms/image/6JE54lRvHIiTAWL
https://sm.ms/image/mMLq49No5hfAKx2
https://sm.ms/image/ng8MtWzpso2DIFfif i don’t use Arrldx, it shows me this for the string: https://sm.ms/image/l5v3QsZzp71on6g
the correct string should looks like: https://sm.ms/image/oMvLWAbqHxTpCtJ
thanks for help
asherb
Participanthello, Mikhail,
I tried your solution, however, the server goes to error, and shows ‘Arrldx’ does not exist in the current context. could you please advise.
Also, for the Byte order in the Modbus template is 76543210, is this byte order should be applied to all str1-str4? since i did not see you apply byte order in your screenshot
thanks
asherb
Participanthello Mikhail:
modbus template and communicator: https://sm.ms/image/KCxcXisOD6Qt3p1
channel configuration: https://sm.ms/image/4bRprKFHcBWISTv
what it show right now : https://sm.ms/image/Zp6YKS83aR7CebH
how it shows in plc : https://sm.ms/image/bRiBrfy3tg6GTXM
please help
thanks
asherb
i tried you mentioned above, however, i got a message in channel like this: https://sm.ms/image/wezHWgTs2JIN6VD
the calculated string channel shows: https://sm.ms/image/3UzKmxgHNMuToyd
the integer channel shows: https://sm.ms/image/Sy537m6tuTq4bsG
it is supposed to show this: https://sm.ms/image/JufC6ojrKMLgviE
please help, thanks
asherb
thank you for your help, i tried, my configuration:
https://sm.ms/image/vr5EZHQi6jToBPKhowever, it shows like random things, btw, the string i have is in english, it shows like this:
https://sm.ms/image/2I8oLSBmE4lsXpaplease let me knwo how i can fix this.
thanks
asherb
I bounded to 4 register of double type (8bytes) in rapid scada, and i tried both unicode and ascii as data type, however, it shows me as a very large number in the modbus current data list, and in the web browser, the string variable only show me ‘—‘,
please let me know what i can do for this.
thanks
asherb
the max length of the string is around 30.
asherb
Participanterror fix, thanks Mikhail!
asherb
asherb
Participantalso, in another log(ModDbExport_001.txt), i can see this:
Current Data
Status : Error
In queue : 762 of 1000
Exported : 56
Skipped : 0asherb
Participanthello, thank you for your reply, i have already installed the 5.8.4 version, should i unstall 5.8.4 and then install 6 or i can go ahead install 6? and also, i see the documentation is very limited for scada6, is there anymore documentation or resources? or i can still see scada 5 documentation for scada6?
thanks!
asher -
