TroyV23
Viewing 9 posts - 31 through 39 (of 39 total)
  • in reply to: Modbus Data Formula #13888
    TroyV23
    I just realized that my received data is missing the last 2 words?
    Sent:
    01 02 00 00 00 06 CE 04 08 0E 00 02
    Response:
    01 02 00 00 00 07 CE 04 04 00 00 FF FF
    I expected response to be:
    01 02 00 00 00 07 CE 04 04 00 00 FF FF 00 00
    Do you have any clues as to why that is?
    in reply to: Modbus Data Formula #13876
    TroyV23
    How Do I capture received data?
    in reply to: Modbus Data Formula #13874
    TroyV23
    • This reply was modified 2 years, 11 months ago by TroyV23.
    in reply to: Chart not Displaying Data #12493
    TroyV23
    I made a mistake, my server is actually running Windows 2012 R2 Server. Is this an issue? Is there a way around it without upgrading the OS ?
    in reply to: Chart not Displaying Data #12472
    TroyV23
    I downloaded Version 6.1.1 and performed update, but there was no change in the text buttons. I am running Windows Server 2016, is that an issue?
    I did not have this problem in RapidScada 5.8.X though, so I’m wondering if my OS version or IIS version is too old for new rapidscada versions. If so Can the remote webstation run a different v5.8.X while my server and communicator on a different machine run v6.1.1 ?
    in reply to: Chart not Displaying Data #12464
    TroyV23
    The language is set to English (UK).
    The report generates, and I can see data in there… although excel doesn’t open the file.
    in reply to: Communicator “File not Found” #12335
    TroyV23
    I have the Communicator running on a separate machine than the Server instance. In the deployment profile of the Communicator PC, I had put the Agent IP as the Remote Server IP, then I get the error of the file not being found. When I change the Agent IP to localhost everything is fine.
    I ended up making a second Deployment profile for the remote server machine, which also hosts the Webstation. That IP is set to the remote server, and connects properly.
    Now I have an issue though, when I try to update the Server functions, they do not take effect, even after restart. Do I have to make those changes on the Server machine directly? I would like to be able to upload changes from my communicator PC to the server.
    in reply to: Remote Communicator Error #12299
    TroyV23
    Thank you, it turned out to be a firewall issue between 2 networks.
    in reply to: Remote Communicator Error #12023
    TroyV23
    I have Agent installed in both places and it is confirmed to be running in task manager. Is there any other configuration I may be missing? The error appears as soon as I try and upload configuration. It is never able to run communicator.
    Not required. You have a PC with a Communicator should be in a separate instance, in which the server address should be specified in the Communicator settings – the 1st PC
    I have defined the server address in Communicator, does the server need to know the address of the communicator as well?
    • This reply was modified 3 years, 10 months ago by TroyV23.
