Viewing 1 post (of 1 total)
haggaipp
ParticipantHi, Mikhail.
Can I get data from this url: http://webserver/scada/ClientApiSvc.svc/GetCurCnlDataExt?cnlNums=&viewIDs=&viewID=1I use XMLHttpRequest in my JS code. But it always says, user not logged in. When i check the ScadaWeb.log it keeps adding User Information in every request. Can you solve this?
My Javascript code:
var xhttp = new XMLHttpRequest(); function main() { xhttp.onreadystatechange = function() { if (this.readyState == 4 && this.status == 200) { // Typical action to be performed when the document is ready: let tmp = JSON.parse(xhttp.responseText); let response = JSON.parse(tmp.d); console.log(response); if (response.Success) { if (response.Data) { getData(); } else { console.log("SERVER NOT LOGGED IN"); logIn(); } } else { console.log("[ERROR]: " + response.ErrorMessage); } } }; xhttp.open("GET", "http://localhost:8080/scada/ClientApiSvc.svc/CheckLoggedOn", true); xhttp.send(); } function logIn() { xhttp.onreadystatechange = function() { if (this.readyState == 4 && this.status == 200) { // Typical action to be performed when the document is ready: let tmp = JSON.parse(xhttp.responseText); let response = JSON.parse(tmp.d); console.log(response); if (response.Success) { if (response.Data) { console.log("LOG IN SUCCESSFUL!"); // getData(); // main(); } else { console.log("FAILED TO LOG IN!"); } } else { console.log("[ERROR]: " + response.ErrorMessage); } } }; xhttp.open("GET", "http://localhost:8080/scada/ClientApiSvc.svc/Login?username=admin&password=12345&callback=true", true); xhttp.send(); } function getData() { xhttp.onreadystatechange = function() { if (this.readyState == 4 && this.status == 200) { // Typical action to be performed when the document is ready: let tmp = JSON.parse(xhttp.responseText); let response = JSON.parse(tmp.d); console.log(response); if (response.Success) { console.log("FETCH DATA SUCCESSFUL!"); console.log(response.Data) } else { console.log("[ERROR]: " + response.ErrorMessage); } } }; xhttp.open("GET", "http://localhost:8080/scada/ClientApiSvc.svc/GetCurCnlDataExt?cnlNums=&viewIDs=&viewID=2&callback=true", true); xhttp.send(); } getData();Scada Web Log:
2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> Request SCADA-Server state 2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> Disconnect from SCADA-Server 2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> Connect to SCADA-Server "localhost" 2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: fgkmemvsn0avgnhrfx1f40sw 2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> Login: admin (Administrator). IP address: ::1 2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> User information has been updated. IP address: ::1. Session: fgkmemvsn0avgnhrfx1f40sw 2022-08-01 20:07:59 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> Retrieve components from the installed plugins 2022-08-01 20:08:01 <DESKTOP-RLH5Q4C><DefaultAppPool><ACT> User information has been added. IP address: ::1. Session: ul23o4sslwbbznovlxl242w2 2022-08-01 20:08:01 <DESKTOP-RLH5Q4C><DefaultAppPool><EXC> Error getting extended current data by the filter where channels=, view id=2: Scada.ScadaException: User not logged on. at Scada.Web.UserMonitor.CheckLoggedOn(UserRights& userRights, Boolean throwOnFail) at Scada.Web.ClientApiSvc.GetCurCnlDataExt(String cnlNums, String viewIDs, Int32 viewID)Or there is the other way to fetch data from OPC server? I use JS and PHP.
Thank You!
