Romiros
Viewing 15 posts - 1 through 15 (of 16 total)
  • in reply to: Evenet Log #9840
    Romiros
    Hi!
    The version of the plugin in the store is working.
    What does not work mean? More details, please.
    Is the module installed and activated?
    What are the errors in the browser console?
    in reply to: Event on change while using formula of stat #9144
    Romiros
    public double LeakValList(params int[] nums)
    for (int i = 0; i < nums.Length; i++)
    In formula LeakValList(101,102,103)
    in reply to: RapidScada OPC DA Server #7428
    Romiros
    in reply to: RapidScada 4.5 Install #469
    Romiros
    Yes you are right. Phe problem was wcf. Now all works. Thank you!
    in reply to: RapidScada 4.5 Install #464
    Romiros
    I do not know will help or not
    IExplorer:
    14‎:‎24‎:‎50 Request diagram data. TimeOffset = 0.59930556712963
    error: 404 Not Found
    Chrome:
    POST http://localhost/Scada/diag/DiagSvc.svc/GetDiagData 404 (Not Found)
    in reply to: RapidScada 4.5 Install #462
    Romiros
    What information do you need?
    in reply to: RapidScada 4.5 Install #457
    Romiros
    I send you ScadaWeb.log. The error disappeared when the new minute archive started.
    But new error – Failed to auto-update chart.
    in reply to: RapidScada 4.5 Install #453
    Romiros
    2. a new day – all works 🙂
    in reply to: RapidScada 4.5 Install #452
    Romiros
    Thank you Mikhail
    1. MS SQL Compact has not been install. I installed manually (Now Scada-Administrator works well).
    2. New error: Specified cast is not valid.
    in reply to: Export data module manual exist? #388
    Romiros
    from log:
    2015-09-01 18:34:05 Ошибка при экспорте текущих данных в БД MySQL – localhost: Duplicate entry ‘2015-09-01 18:32:42-1’ for key ‘PRIMARY’
    from log 2:
    Модуль экспорта данных
    Состояние: норма
    Источники данных
    1. MySQL – localhost; состояние: ошибка экспорта; в очереди тек/арх/соб: 5/0/0; экспортировано тек/арх/соб: 18/0/11; пропущено тек/арх/соб: 0/0/0
    Current data is written normally, although the error log. Archives no. Another question – historical data are written into the same table, or need to create another?
    Прошу прощения за мой английский
    Текущие данные пишутся нормально, хотя в логе ошибка. Архивов нет. Еще вопрос – архивные данные пишутся в ту же таблицу или надо создавать отдельную?
    in reply to: Export data module manual exist? #379
    Romiros
    SQL query from tab “Arh Data” (Архивные данные) in the export module dont work
    in Scada minute and hour records are present.
    I use MySQL.
    in reply to: Export data module manual exist? #370
    Romiros
    Hi, I’ve read manual
    Current data and Events work.
    Archive data dont work. There may be additional options?
    in reply to: how to access web interface from other computer #361
    Romiros
    computer name
    anyuser-pc/scada
    in reply to: Export data module manual exist? #359
    Romiros
    Romiros
    RapidScada version? Physical Path : C:\inetpub\wwwroot\scada – old version
    OS is Windows7 ?
    ScadaWeb install correctly?
    Open IIS manager and сheck whether the application exists “Scada” in “Default Web Site”
