tina_y
  • in reply to: Rapid SCADA 6 Beta #10436
    tina_y
    > 1. On V5 if the formula used channel exceed ~1.5k, the server will crash.
    Is there a solution to this problem on V5? I have to divide each channel by a variable ratio in my application, about 15 k.
    In the meantime, I suggest adding a column for “ratio” in the channel in V6 (default value= 1, can set it to 0.1 or 10 …). Because multiply or divide with a ratio is very common. I think it would be more convenient than using formula.
    in reply to: Rapid SCADA 6 Beta #10428
    tina_y
    Hi Mikhail
    The new version is more convenient and flexible. You’ve done a great job.
    A test feedback of V6 beta 8:
    –Test condition : two same devices /modbus rtu/read 560 Registers/wirte 28 Registers
    –Problem: After adding channels, When I change the “Data Type” to “Integer”, the communicator loses the channel matching, the data can’t be sent to channels. but, It is normal when changed to “Double ” or “NULL”.
    In addition,When I use “ export… ” to export channels to CSV files, and I have a coding problem If I use simplified Chinese in channel names.
    If you need a new simplified Chinese language pack, I’d be glad to do it.
