manyan2028ParticipantI want to use the RapidScada 6 ,thanks。
manyan2028Participanthttps://rapidscada.org/download-all-files/download-elastic-report-plugin/
I downLoad the file from the Above link。But it doesnot contain the files:report-args.min.css , report-args.js.
manyan2028ParticipantHello, the ElasticReport File donnot contain the above Files. can you privide the new Link to me。thanks
manyan2028Participant2023-06-28 13:54:46 Error transferring current data:
Scada.Protocol.ProtocolException: Server and client secret keys do not match.
at Scada.Client.ClientBase.GetSessionInfo(Int64& sessionID, String& serverName)
at Scada.Client.ClientBase.RestoreConnection()
at Scada.Client.ScadaClient.WriteChannelData(Int32 archiveMask, ICollection`1 slices, WriteDataFlags flags)
at e.k()
manyan2028ParticipantHello,Mikhail,my log output as follow:(the connection option password is scada,not the sacada)
Gateway State
Name : [1] [GateName]
Server : 10.1.20.188
Connection : ErrorCurrent Data
Status : Error
In queue : 13 of 1000
Exported : 0
Skipped : 0Historical Data
Status : Normal
In queue : 0 of 1000
Exported : 0
Skipped : 0Events
Status : Error
In queue : 127 of 1000
Exported : 0
Skipped : 0Event Acknowledgements
Status : Normal
Exported : 0
Skipped : 0Incoming Commands
Status : Enabled
Received : 0Outcoming Commands
Status : Normal
Exported : 0
Skipped : 0Archive Replication
Is ready : Yes
Tasks in queue : 0 of 10
Task : None
manyan2028Participanthello Mikhail
I donot know how to config the Option to achieve data transfer between rapidSCADAs。 In connection Option host is the remote PC IP,username admin password scada 。 port and the TimeOUt is the default。 the instance and the Secret Key is null . uopload the Project to the PC .BUt I cannot rececive the Current Data in the Remote PC。can you help me to finish the test environment.
manyan2028Participanthello Mikhail, I receive you reply about the ElasticReport, press the F12, I get the follow infomation.
Failed to load resource:the Server Responded with a status of 404(not found)。the file report-args.min.css , report-args.js connot found in my PC。
I donot know how to config the Option to achieve data transfer between rapidSCADAs。 In connection Option host is the remote PC IP,username admin password sacada 。 port and the TimeOUt is the default。 the instance and the Secret Key is null . uopload the Project to the PC .BUt I cannot rececive the Current Data in the Remote PC。can you help me to finish the test environment.
manyan2028Participant2022-07-13 15:07:48 Unable to communicate with Device 1 “GetAB Data” because connection is not established.
how to use this KP,I cannot connunicate the AB PLC device. windows 10 X64 -
