March 4, 2024 at 4:38 pm in reply to: Scheme Editor cannot load from Administrator app V6.0.2 #14131
CCKOH
ParticipantHi Mikhail,
Thanks a lot for your guidance.
Have change the path to ScadaSchemeEditor.exe
Now the Scheme Editor can load from Administrator App already.CCKOH
Thank for the explanation.
If I’m need to execute my function “Compute()” every 5 second define by user thru channel 140 for example, can I’m write the formula as EveryPeriod (Compute(), Val(140), Val(140)/10) at the channel of output formula column?
I’m still confusing why we still need execSpan argument? As we already define function Compute() only can be execute when the time specific (5s in this example) elapsed. Really hope you can help elaborate more on it.
March 1, 2024 at 5:53 am in reply to: SCADA 6.2.0 Installation Error – TCP Port already in use #14097CCKOH
I’m have found out the issue is due to the previous version on Rapid SCADA I’m HV installed in my computer.
Have stop the SCADA agent services and now the V6.2.0 have been successful installed ?September 22, 2022 at 1:18 am in reply to: How to Install Automatic Control Module in Raspberry PI #10873CCKOH
Thank for your guidance.
After check the ScadaServerConfig.xml, the script do not contains “ModAutoControl”
Im realise during uploading of configuration, im have unchecked the Server option.
Once im Check back the option and uploading again, everything working fine now 🙂September 21, 2022 at 12:37 am in reply to: How to Install Automatic Control Module in Raspberry PI #10847CCKOH
ModAutoControl.log does not exist.
ScadaServerSvc.log do not show any error.
Im try to copy my whole project folder to Linux machine and run Administrator using Linux machine to obtain the computer code, but unsuccessful. Under the Auto Control Modules – Registration, the computer code area is empty and with a msg “to restart Scada Svc to obtain computer code”. Im try to restart Server using Administrator – Instances, but it show error msg “Invalid Username and Password”
Im have run out of idea ?September 19, 2022 at 4:51 pm in reply to: How to Install Automatic Control Module in Raspberry PI #10839CCKOH
I’m have copy the files \mod_auto_control_5.2.5.3_en\SCADA to both Windows and Linux machine.
I’m have activate the module in Windows Machine and the module is function perfectly.
I’m have Upload the Configuration to Linux Machine by using New Deployment profile for Linux Machine. However, the Auto Control Modules do not start and i’m do not find any computer code under dir scada/ScadaServer/Log.
Please guides me how to Activate the Auto Control Module for Linux Machine by using Administrator?
CCKOH
ParticipantHi Manjey,
Thank a lot for your guidance, I’m have try change for other port, but still not working.
At the end, I’m overwrite again the /scada/opt/ScadaServer folder. Now it is working. 🙂
CCKOH
Any idea on how to check port 10000 use by which Services?CCKOH
I’m not sure how to changing all the specific paths to /opt/scada.
I’m have change the Server – Common Parameters to Default for Linux before upload the configuration.
CCKOH
Thank a lot for your prompt reply.
It is working now. 🙂
