modivirParticipantHi,
Thanks for support. Problem is solved after below changes.
1) Calculated Output
2) input formula -Val(206)
3) Output Formula – SetVal(206,Val(206) > 0 ? 0 : 1)
modivirParticipantHI,
I used scheme classic.
I USED MODBUS SLAVE SOFTWARE FOR MODBUS COMMUNICATION. IT’S NOT TIED WITH PHYSICAL DEVICE. i shared screenshot of configuration. please check and let me know if any mistake is there. i used 206 channel (coil 1 ).thanks in advance.
https://ibb.co/8DyCQwMt
https://ibb.co/B031Vh5
https://ibb.co/Ng5LsdHP
https://ibb.co/gbRDwkGS-
This reply was modified 9 months, 2 weeks ago by
modivirParticipanthi,
I use Val() > 0 ? 0: 1 in output formula and Val() in input formula. still problem is not solve.
I used Val() in the input channel, but the toggle always sends 1.<img https://ibb.co/39b7hN4W
https://ibb.co/DfDjWbnN-
first of all sorryThere is a separate file called a faceplate. How is this faceplate used in the Scheme Classic / Mimic Diagram so that, when an operator clicks on a pump or valve in the overview screen, the corresponding popup faceplate opens and shows control and status details?
We would like to implement standard popup faceplates for pump and valve operation within the SCADA system.
On the overview screen, two pumps and two valves will be displayed. When the operator clicks on any pump or valve, a compact faceplate will open as a popup window.
Pump Faceplate
The pump faceplate will provide the following indications and controls:
Pump running status feedback
Pump trip / fault status feedback
Pump start push button
Pump stop push buttonValve Faceplate
The valve faceplate will provide the following indications and controls:
Valve open status feedback
Valve close status feedback
Valve open push button
Valve close push button
The same pump faceplate and valve faceplate designs will be reused for all pumps and valves. The displayed data and controls will automatically update based on the selected equipment.
I used input/output channel type but it only send COMMAND 1. its not working like toggle.
https://ibb.co/xKkg20np send command-
This reply was modified 9 months, 3 weeks ago by
modivirParticipantHi mikhail,
I use your formula in script table and added in output channel no.204. but when I click on toggle switch it sends only 1 not 0. can you please help me. I used sends command now.
Thanks in advance.
https://ibb.co/cXtWDDX6
https://ibb.co/20RqPLJv
https://ibb.co/PZZ7jykL
https://ibb.co/wFXXWTSZ-
November 26, 2025 at 11:05 am in reply to: Regarding Map Plugin Data Integration from SQL Database #17346
Will it show real-time data or schedule synchronization?
modivirParticipantYES, ATTACHED IN ABOVE LINK
modivirParticipantPlease explain how to disable password from button.
modivirParticipantSo is it possible to disable password to operate button
