fedex
it worked by only copying the libraries to the /usr/lib directory.
Thank you.fedex
ParticipantOk.
Thank you.fedex
I solved with:
export LD_LIBRARY_PATH
For windows LibplctagWrapper.dll uses plctag.dll.
What needs to be changed to use libplctag.so.2.3.
Thank you.fedex
i have the same version of raspberry.
I tried to run an example contained in the library, I have this error:pi@raspberry:~ $ ./simple
./simple: error while loading shared libraries: libplctag.so.2.3: cannot open shared object file: No such file or directoryThe libraries libplctag.so.2.3 is in the same directory as simple.
Thank you for your help.
fedex
ParticipantHi
is it possible to use this driver on raspberry?
Thank you.fedex
can you tell me what to check?
I have made some tests but I cannot solve the problem.fedex
the problem is the link to the web application:
sudo ln -s /opt/scada/ScadaWeb /var/www/html/scada
I copied ScadaWeb into /var/www/html/scada and it works.
Do you have ideas to solve the problem?fedex
i tried, with version 4 of mono, the web application worked.fedex
i installed version 6 of mono, but now i get this error from the web application:Description: HTTP 404.The resource you are looking for (or one of its dependencies) could have been removed, had its name changed, or is temporarily unavailable. Please review the following URL and make sure that it is spelled correctly.
Details: Requested URL: /scada/
No log in /opt/scada/ScadaWeb/log
What can I check?
thank you.-
This reply was modified 5 years, 8 months ago by
fedex.
fedex
this is the version:
Mono JIT compiler version 4.6.2 (Debian 4.6.2.7+dfsg-1)fedex
now i can’t check.
What is the correct version?fedex
Can you help me, thanksfedex
the files are present.
The web application works with the sample project.
This is the error:
pi@raspberry:~ $ mono /opt/scada/ScadaAgent/ScadaAgentMono.exeUnhandled Exception:
System.IO.FileNotFoundException: Could not load file or assembly or one of its dependencies.
File name: ‘netstandard, Version=2.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’Thanks
fedex
I attach the dll to the process ScadaCommSvc.exe.
Thanks for the support.fedex
thanks for article and examples.
Where do I find ScadaComm.exe, and how do I attach the dll to the process?
Thanks for the support. -
