Zeus
Viewing 15 posts - 106 through 120 (of 165 total)
  • in reply to: scada forum #9243
    Zeus
    Thanks a lot. Could you give me some authority to manage the branch?
    in reply to: scada forum #9239
    Zeus
    Yes, there are many Chinese people using this project. But they don’t speak English.
    I will answer questions if they speak Chinese.
    in reply to: SCADA V6 #9232
    Zeus
    I got a problem running SCADA web V6. The log file is below
    2021-07-08 16:59:19 [DESKTOP-N1KQU2A][Zeus][ACT] Webstation 6.0.0.0 started
    2021-07-08 16:59:19 [DESKTOP-N1KQU2A][Zeus][ERR] Unable to create plugin logic PlgChart. File C:\Users\Zeus\Desktop\SCADA\ScadaWeb\PlgChart.dll not found
    2021-07-08 16:59:19 [DESKTOP-N1KQU2A][Zeus][ACT] Loaded plugin PlgMain 6.0.0.0 from file C:\Users\Zeus\Desktop\SCADA\ScadaWeb\PlgMain.dll
    2021-07-08 16:59:19 [DESKTOP-N1KQU2A][Zeus][ERR] Unable to create plugin logic PlgScheme. File C:\Users\Zeus\Desktop\SCADA\ScadaWeb\PlgScheme.dll not found
    2021-07-08 16:59:24 [DESKTOP-N1KQU2A][Zeus][ACT] The configuration database has been received successfully
    2021-07-08 16:59:24 [DESKTOP-N1KQU2A][Zeus][EXC] Error updating configuration:
    System.ArgumentOutOfRangeException: Length cannot be less than zero. (Parameter ‘length’)
    at System.String.Substring(Int32 startIndex, Int32 length)
    at Scada.CnlDataFormatter.FillEnumColors()
    at Scada.CnlDataFormatter..ctor(BaseDataSet baseDataSet)
    at Scada.Web.Code.WebContext.ExecuteConfigUpdate() in E:\scada-v6\ScadaWeb\ScadaWeb\ScadaWeb\Code\WebContext.cs:line 306
    in reply to: dbexport module affect the command #9205
    Zeus
    hi,
    I changed the code.
    https://ibb.co/Z8csbW0
    In the DB Export module. If we received the command and we enable current data export. passToClients is always false. and the device could not receive commands. the command is canceled. and only the command type BaseValues.CmdTypes.Binary is handled.
    I don’t know why we cancel it if we use DB Export module.
    in reply to: dbexport module affect the command #9204
    Zeus
    hi,
    Should I config the input channel to fill the output channel grid with the output channel number?
    I checked the DB Export module. I only configured the current data export with SQL below.
    INSERT INTO cnldata (datetime, cnlnum, val, stat)
    VALUES (:dateTime, :cnlNum, :val, :stat)
    The database is Oracle 11g and I changed SQL ‘@val’ to ‘:val’.
    My version is 5.8.2 and I don’t find any grid to config the DB Export module output channel settings.
    in reply to: cunstom page develop #9198
    Zeus
    hi,
    I see. I will develop a method POST. That is a good idea. Thanks a lot.
    in reply to: cunstom page develop #9184
    Zeus
    hi,
    the first picture is below
    https://ibb.co/xYWgvCw
    in reply to: SCADA V6 #9175
    Zeus
    hi,
    I have tried to develop an SVG component.
    https://ibb.co/xHBVxxX
    in reply to: SCADA V6 #9099
    Zeus
    first of all, I will migrate the driver developed before.
    then I will develop the web with ant design of Vue.
    by the end, I will develop the web plugin with echart.js and svg editor. develop components like topology and the project Fuxa in github.
    https://ibb.co/9p1rZMf
    https://ibb.co/YbmvwRn
    https://ibb.co/6802m9M
    in reply to: SCADA V6 #9097
    Zeus
    hi,
    it works.
    I am focusing on this project.
    while the server and comm are done. I will do some work on the web and make it a great project.
    https://ibb.co/yX1sRLB
    in reply to: SCADA V6 #9096
    Zeus
    yes, I run it as exe.
    in reply to: SCADA V6 #9089
    Zeus
    thanks a lot.
    the ScadaCommonSvc is not ready so that the ScadaAdmin could not upload the BaseDat file. the ScadaServer could not run correctly and so as the ScadaWeb.
    in reply to: SCADA V6 #9084
    Zeus
    hi
    include it in the project for testing may be a good idea
    in reply to: SCADA V6 #9083
    Zeus
    hi
    could you please send me each config file of this project to run it?
    I know it is still in development. I just want to run it.
    in reply to: scheme editor #8953
    Zeus
    only the important events were checked with sound. so it would not be so much.
