ZeusParticipant
ZeusParticipantHi,
In the eventlog.js
var json = /var/www/html\interface/eventlog.xml does not exsit
ZeusParticipantexcellent
ZeusParticipantIn the configuration database-dictionary-units of V5 Id 16(Off-On). The color is red and green. Sometimes we need it to be green and red. We used to config event type and set stat of input data. It’s not convenient. Will there be a new unit Off shows green and On shows red?
ZeusParticipantGood! Device state is enough.
ZeusParticipant分表了么?历史和实时的表要分开
ZeusParticipant有道理
ZeusParticipant上生产最好大内存,应该没什么问题
ZeusParticipant还有这种情况吗? 我还真没遇到过啊。 28000点确实不少,你内存一共多大,有16GB么
ZeusParticipantHi,
That is the solution. The 4G DTU contains the config.
ZeusParticipantLooks good. I will try. That’s a good idea.
ZeusParticipantHi,
You did not get my point. I tried all modes. they are all not working correctly. By IP is not the solution and the other two modes are also not the solution
ZeusParticipantYes, The DTU module is a TCP client and the line is a TCP server. you can see it in my question.
This reply was modified 4 years, 11 months ago by
Zeus.
ZeusParticipantHi,
Random IP address is disgusting.
ZeusParticipantHi,
Yes. There is a config in the DTU module. TCP Server IP address and port. -
