Zeus
Viewing 15 posts - 151 through 165 (of 165 total)
  • in reply to: rapidgate module bug #8384
    Zeus
    there is only one line in log file
    2021-03-03 09:14:59 Start ModRapidGate module
    i tried the version ModRapidGateUpdate.zip which i downloaded in the forum. i stored it in my computer.this version work right in any system.but the version 5.1.1.0 doesn’t work right. hope you can fix it.
    in reply to: rapidgate module bug #8368
    Zeus
    i don’t know how to fix it and make it work
    in reply to: rapidgate module bug #8367
    Zeus
    i have tried windows server2016 server2019 windows 10 the gate module is the same condition.
    the log file is below
    2021-03-02 14:17:41 <2P27P129><SYSTEM><ACT> ScadaServerService 5.1.4.1 is started
    2021-03-02 14:17:41 <2P27P129><SYSTEM><ACT> Module is loaded from the file D:\SCADA\ScadaServer\Mod\ModRapidGate.dll
    2021-03-02 14:17:41 <2P27P129><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2021-03-02 14:17:41 <2P27P129><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 5
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Ouput channels are read from the configuration database
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Users are read from the configuration database
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Formulas are read from the configuration database
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> The formulas source code has been compiled
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Connection listener is started
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Start server
    2021-03-02 14:17:42 <2P27P129><SYSTEM><EXC> Error executing actions on server start in module ModRapidGate: 值不能为 null。
    参数名: format
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Current data are loaded
    2021-03-02 14:17:42 <2P27P129><SYSTEM><ACT> Connect to client 127.0.0.1
    2021-03-02 14:17:43 <2P27P129><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2021-03-02 14:17:44 <2P27P129><SYSTEM><EXC> Error executing actions on current data processing in module ModRapidGate: 未将对象引用设置到对象的实例。
    2021-03-02 14:17:44 <2P27P129><SYSTEM><EXC> Error executing actions on current data processed in module ModRapidGate: 未将对象引用设置到对象的实例。
    2021-03-02 14:17:45 <2P27P129><SYSTEM><EXC> Error executing actions on current data processing in module ModRapidGate: 未将对象引用设置到对象的实例。
    2021-03-02 14:17:45 <2P27P129><SYSTEM><EXC> Error executing actions on current data processed in module ModRapidGate: 未将对象引用设置到对象的实例。
    2021-03-02 14:17:46 <2P27P129><SYSTEM><EXC> Error executing actions on current data processing in module ModRapidGate: 未将对象引用设置到对象的实例。
    2021-03-02 14:17:46 <2P27P129><SYSTEM><EXC> Error executing actions on current data processed in module ModRapidGate: 未将对象引用设置到对象的实例。
    in reply to: rapidgate module bug #8361
    Zeus
    log below
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> ScadaServerService 5.1.4.1 is started
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Module is loaded from the file C:\SCADA\ScadaServer\Mod\ModActiveDirectory.dll
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Module is loaded from the file C:\SCADA\ScadaServer\Mod\ModRapidGate.dll
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Check the existence of the data directories is completed successfully
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 5
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Ouput channels are read from the configuration database
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Users are read from the configuration database
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Formulas are read from the configuration database
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> The formulas source code has been compiled
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Connection listener is started
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Start server
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><EXC> Error executing actions on server start in module ModRapidGate: 值不能为 null。
    参数名: format
    2021-03-01 16:51:53 <DESKTOP-N1KQU2A><SYSTEM><ACT> Current data are loaded
    2021-03-01 16:51:54 <DESKTOP-N1KQU2A><SYSTEM><ACT> Connect to client 127.0.0.1
    2021-03-01 16:51:54 <DESKTOP-N1KQU2A><SYSTEM><ACT> The user ScadaComm is successfully authenticated
    2021-03-01 16:51:55 <DESKTOP-N1KQU2A><SYSTEM><EXC> Error executing actions on current data processing in module ModRapidGate: 未将对象引用设置到对象的实例。
    in reply to: rapidgate module bug #8359
    Zeus
    参数名: format
    in reply to: get line state #8349
    Zeus
    it is a good idea thanks
    but it will cost plenty to config input channel.
    i write a kpdriver to analysis the commonsvc log file and a send status to inputchannels there are four states.you can see it in project code.
    i use a master server and many slave servers in a large project. i use gate module to send data between them.
    i also write a kpdriver to monitor the tcp status between servers.
    i write an big screen project to show tcp state and line state.
    Zeus
    there is something wrong with module rapid gate. version of server is 5.1.4.1 and version of is 5.1.1.0. there is an error message while server start Error executing actions on server start in module ModRapidGate: Value cannot be null.
    Parameter name: format
    in reply to: get line state #8342
    Zeus
    hi
    i have an idea. i will write a kpdriver to analysis the commonsvc log file and send the status to input channel. it would help me solve my problem.
    is that good ahaha
    in reply to: sec data save #8341
    Zeus
    hi 123abc56
    you solved my problem,but have you tested dbexport module to save data into other database and i also write a driver to export curdata into influxdb with code oncurdataprocessed. thanks a lot
    in reply to: SCADA V6 #8256
    Zeus
    ok i see. thanks a lot. hope it come soon. yeah! i have many ideas to design V6 web application.
    in reply to: about module rapid gate #8103
    Zeus
    i have solved my porblem,thanks.
    install rapidgate on the master server to send command to slave server
    in reply to: about module rapid gate #8077
    Zeus
    my master server could receive commands info from slave server,but while i use generater in master server send commands to the device of slave it won’t work.
    in reply to: about module rapid gate #8076
    Zeus
    i set transfer options Incoming command enable and OutComing command enable
    in reply to: about module rapid gate #7978
    Zeus
    i have make it work,but i have some question about this module,will the gate module send history data to server while network return to work to keep the data of server complete,for example the network is failed for some reason from 1:00 to 2:00 and back to work at 2:00,will the gate module send data in 1:00 to 2:00 to the server? if i want to realize this function, what should i do?
    Zeus
    hi Mikhail
    my xml file config is below
    <ModRapidGate>
    <Gate>
    <GeneralOptions>
    <Active>true</Active>
    <ID>1</ID>
    <Name>Gate 1</Name>
    <MaxQueueSize>1000</MaxQueueSize>
    <MaxWaitingTime>3600</MaxWaitingTime>
    <DataLifetime>30</DataLifetime>
    <OutCnlNum>0</OutCnlNum>
    </GeneralOptions>
    <ConnectionOptions>
    <Host>10.63.24.35</Host>
    <Port>10000</Port>
    <User>ScadaAdmin</User>
    <Password>672C3165774A308878A00927A987C759</Password>
    <Timeout>10000</Timeout>
    </ConnectionOptions>
    <MappingOptions>
    <CnlMappings>
    <MappingItem localIDs=”101-105″ remoteIDs=”201-205″ />
    </CnlMappings>
    <OutCnlMappings />
    <ObjMappings>
    <MappingItem localIDs=”1″ remoteIDs=”1″ />
    </ObjMappings>
    <DeviceMappings>
    <MappingItem localIDs=”1″ remoteIDs=”2″ />
    </DeviceMappings>
    </MappingOptions>
    <TransferOptions>
    <CurDataTransferOptions enabled=”true”>
    <Trigger>OnTimer</Trigger>
    <UseRawData>false</UseRawData>
    <SkipUnchangedData>false</SkipUnchangedData>
    <IncludeCalculatedCnls>false</IncludeCalculatedCnls>
    <TimerPeriod>1000</TimerPeriod>
    </CurDataTransferOptions>
    <ArcDataTransferOptions enabled=”true”>
    </ArcDataTransferOptions>
    <EventTransferOptions enabled=”true” />
    <InCmdTransferOptions enabled=”true”>
    <PollingRate>1000</PollingRate>
    </InCmdTransferOptions>
    <OutCmdTransferOptions enabled=”true” />
    <ArcUploadOptions enabled=”true”>
    <SnapshotType>Min</SnapshotType>
    <Delay>10000</Delay>
    <MaxAge>1</MaxAge>
    </ArcUploadOptions>
    </TransferOptions>
    </Gate>
    </ModRapidGate>
    and this is my server input channels
    <ArrayOfInCnl xmlns:xsi=”http://www.w3.org/2001/XMLSchema-instance&#8221; xmlns:xsd=”http://www.w3.org/2001/XMLSchema”&gt;
    <InCnl>
    <CnlNum>101</CnlNum>
    <Name>Simulator – Sine</Name>
    <CnlTypeID>2</CnlTypeID>
    <ObjNum>1</ObjNum>
    <KPNum>1</KPNum>
    <Signal>1</Signal>
    <FormulaUsed>false</FormulaUsed>
    <Formula />
    <Averaging>false</Averaging>
    <ParamID xsi:nil=”true” />
    <FormatID>3</FormatID>
    <UnitID xsi:nil=”true” />
    <CtrlCnlNum xsi:nil=”true” />
    <EvEnabled>false</EvEnabled>
    <EvSound>false</EvSound>
    <EvOnChange>false</EvOnChange>
    <EvOnUndef>false</EvOnUndef>
    <LimLowCrash xsi:nil=”true” />
    <LimLow xsi:nil=”true” />
    <LimHigh xsi:nil=”true” />
    <LimHighCrash xsi:nil=”true” />
    </InCnl>
    <InCnl>
    <CnlNum>102</CnlNum>
    <Name>Simulator – Square</Name>
    <CnlTypeID>1</CnlTypeID>
    <ObjNum>1</ObjNum>
    <KPNum>1</KPNum>
    <Signal>2</Signal>
    <Formula />
    <FormatID>10</FormatID>
    <UnitID>16</UnitID>
    </InCnl>
    <InCnl>
    <CnlNum>103</CnlNum>
    <Name>Simulator – Triangle</Name>
    <ObjNum>1</ObjNum>
    <KPNum>1</KPNum>
    <Signal>3</Signal>
    <Formula />
    </InCnl>
    <InCnl>
    <CnlNum>104</CnlNum>
    <Name>Simulator – Relay State</Name>
    <ObjNum>1</ObjNum>
    <KPNum>1</KPNum>
    <Signal>4</Signal>
    <Formula />
    <UnitID>16</UnitID>
    <CtrlCnlNum>101</CtrlCnlNum>
    </InCnl>
    <InCnl>
    <CnlNum>105</CnlNum>
    <Name>Simulator – Analog Output</Name>
    <ObjNum>1</ObjNum>
    <KPNum>1</KPNum>
    <Signal>5</Signal>
    <Formula />
    <CtrlCnlNum>102</CtrlCnlNum>
    </InCnl>
    <InCnl>
    <CnlNum>201</CnlNum>
    <Name>Simulator – Sine2</Name>
    <ObjNum>1</ObjNum>
    <KPNum>2</KPNum>
    <Signal xsi:nil=”true” />
    <Formula />
    </InCnl>
    <InCnl>
    <CnlNum>202</CnlNum>
    <Name>Simulator – Square2</Name>
    <ObjNum>1</ObjNum>
    <KPNum>2</KPNum>
    <Formula />
    <UnitID>16</UnitID>
    </InCnl>
    <InCnl>
    <CnlNum>203</CnlNum>
    <Name>Simulator – Triangle2</Name>
    <ObjNum>1</ObjNum>
    <KPNum>2</KPNum>
    <Formula />
    </InCnl>
    <InCnl>
    <CnlNum>204</CnlNum>
    <Name>Simulator – Relay State2</Name>
    <ObjNum>1</ObjNum>
    <KPNum>2</KPNum>
    <Formula />
    <UnitID>16</UnitID>
    </InCnl>
    <InCnl>
    <CnlNum>205</CnlNum>
    <Name>Simulator – Analog Output2</Name>
    <ObjNum>1</ObjNum>
    <KPNum>2</KPNum>
    <Formula />
    </InCnl>
    </ArrayOfInCnl>
    my server cannot receive data from rapid gate,could you tell me how to config the server and gate to make it work right,best regards.
