ZeusParticipanthope the project v6 support string value in input channel
ZeusParticipantHi
there is another problem.
the registration code of Gate module is different from the others.
How can I fix it?
ZeusParticipantThanks a lot.
I see.
I will try it myself.
ZeusParticipanthi
there is another error on gate 5.1.1.1
the log file is below2021-04-07 17:23:23 <DESKTOP-N1KQU2A><SYSTEM><EXC> Error executing actions on server start in module ModRapidGate: 未能从程序集“ScadaData, Version=5.1.5.0, Culture=neutral, PublicKeyToken=null”中加载类型“Scada.Data.Models.QueueItem`1”。
2021-04-07 17:23:23 <DESKTOP-N1KQU2A><SYSTEM><ACT> Current data are loaded
2021-04-07 17:23:25 <DESKTOP-N1KQU2A><SYSTEM><ACT> Connect to client 127.0.0.1
2021-04-07 17:23:25 <DESKTOP-N1KQU2A><SYSTEM><ACT> The user ScadaComm is successfully authenticated
ZeusParticipantok
thanks
I have a question about the scada comm line.
how can I get each active devices state of comm lines.
ZeusParticipantHi,
you are right.
there is no much developer using blazor.
the best way may be Vue React or Anjular
ZeusParticipanthi
will the v6 use blazor?
there is a project ant-design-blazor.
it is a good idea to use this project.
https://github.com/ant-design-blazor/ant-design-blazor
ZeusParticipantHi,
I see hope it comming soon.
ZeusParticipanthi Mikhail
the DBMS i will choose sqlserver.However, I know one guy ported configuration database to PostgreSQL and inte
grated it with the existing Agent service to upload projects to Rapid SCADA
runtime.could you give me the url of this project?
i have write some kpdrivers moddrivers. how can i put it on website and sell it?
ZeusParticipantif the V6 is still saved in xml file. i am going to write a vue.js project to handle all config file and save them in my own db by .Net5 backend
ZeusParticipanthi manjey73
i know about it.
when you try to do some job such as data analysis or bussiness intelligence.
you have to build device mapping line mapping and cnl mapping in you own system.
the xml file is in different project.
is not a good way to handle xml file.
but if i have config saved in database.
it is convinent to use ORM read all relationships of the running project.
i have done much work on rapid scada.
i really love it.
ZeusParticipantwill all configuration file save in database such as sqlserver mysql oracle and so on. it is not convient to handle xml files. especially in eneity mapping.
ZeusParticipanti have a friend he could translate it for me. will you send the file.
the .Net6 is coming and Blazor is a way to build web app.
i use vue.js a lot. i think i will translate the razor page into vue.js if i have time.
i used to use razor. it is not confotable and low efficiency for me.
ZeusParticipantthanks a lot.
ZeusParticipantyes the gate update version works correct.
but the register computer code is different from other computer code.
hope 5.1.1.1 comming soon.
best regards -
