Omega3.1
Okay
Thanks,
Wanchai P.Omega3.1
ParticipantHi, Mikhil
Thanks for your advice, I can install and open Administrator icon but stll can’t connec’t to Web station (Server is unavailable)
After finished installation show as below detai;
Install Agent application
Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaAgent.zip
Install service ScadaAgentService
Process completed with an error
Installation of Agent application has completed with a error:
Service ScadaAgentService hasn’t been installedRegards,
Wanchai P.Omega3.1
ParticipantRapid SCADA 5.8.2 Installation
Create directory C:\ProgramData\Microsoft\Windows\Start Menu\Programs\SCADAInstall Server application
Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaServer.zip
Install service ScadaServerService
Installation of Server application has completed successfullyInstall Communicator application
Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaComm.zip
Install service ScadaCommService
Installation of Communicator application has completed successfullyCheck the configuration of Internet Information Services (IIS)
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaWeb.zip
Selected application pool: DefaultAppPool
Register web application Scada
Create shortcut Webstation
Installation of Webstation application has completed successfullyInstall Agent application
Installation of Agent application has completed successfullyInstall Administrator application
Installation of Administrator application has completed with a error:
Directory C:\SCADA\Projects has to be clearedInstall Scheme Editor application
Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaSchemeEditor.zip
Installation of Scheme Editor application has completed successfullyInstall Table Editor application
Unzip files from D:\WORK SDS\Manual\OTHER\Rapid SCADA\scada_5.8.2_full_en\Arc\ScadaTableEditor.zip
Installation of Table Editor application has completed successfullyInstallation has completed with errors
Please restart the computer -
