Romanljw
ParticipantHi, Mikhail, thanks a lot.
Romanljw
ParticipantHi Mikhail, I have solved the problem. The configuration of the KpMQTT is as similar as Modbus. Thanks a lot.
Romanljw
ParticipantIt seems that the image can’t display.
The url of the administrator image is: https://nis.nikonimagespace.com/html/guest/index.html?g=yDwXbeqIp564THYmPC2JDZ6cazaPiG9DXDLEDfl2IhbBeBYalXnBJkCxErUWK-SD-i3rhYdqa3GDuqEjKQPgYwThe url of the config image is: https://nis.nikonimagespace.com/html/guest/index.html?g=yDwXbeqIp564THYmPC2JDZ6cazaPiG9DSp-KutfK3zXBeBYalXnBJkCxErUWK-SD-i3rhYdqa3GDuqEjKQPgYw
Romanljw
ParticipantHi Mikhail, thinks for your kindly reply. The Administrator’s screenshot is as follows.It shows the position of the MQTT command button in the Administrator.
The command number is configured in the KpMqtt_Config.xml which is shown as follows.
Thanks a lot.
Romanljw
ParticipantHi, Mikhail, thanks for your replay. I have config the MQTT command in the KpMqtt_Config.xml file, and successfully sent the commands from Administrator.
Romanljw
ParticipantHi, Mikhail, thanks for your help. I wander how to send command using KpMQTT via the Scheme Editor. Thus I can send commands via the interface in browser. Can you describe the steps in detail? Thanks a lot.
Romanljw
Romanljw
ParticipantThanks a lot to you kindly reply. I’ll try to config the settings. It seemed effective.
