kcks66
Viewing 15 posts - 151 through 165 (of 183 total)
  • in reply to: Get data from excel into DAT files #8980
    kcks66
    Hi Mikhail,
    Previously I manually insert every month data (one month one data, from 2017 – 2020) into ArchiveDAT\Hour by using Generator. So far this method served me well.
    However, my project is getting more complicated as needed now; I need to import old data (one minute one data and one hour one data, from 2017 – 2020). I don’t think I can still use the manually insert by Generator way anymore.
    I remember you mention about an utility should be developed for this kind of massive job. I would like to explore now.
    Pls advice for how shall we start talking about the development of the utility.
    • This reply was modified 5 years, 5 months ago by kcks66.
    in reply to: Change event type color #8919
    kcks66
    Hi Mikhail,
    It is worked after I added 3rd value of the unit.
    in reply to: Change event type color #8893
    kcks66
    Hi manjey73,
    I tried as your advice.
    https://ibb.co/DQgR9sr
    https://ibb.co/275kmrx
    However, the event status color still remain unchanged.
    Pls advice and thank you.
    in reply to: About Elastic Report Month Period #8555
    kcks66
    Hi Mikhail,
    Done. Thank you.
    in reply to: About Elastic Report Month Period #8547
    kcks66
    Hi Mikhail,
    I have question to ask; how I am going to change the Subtitle as below to desired name?
    2. Elastic report –> Other name 1
    3. Elastic report –> Other name 2
    https://ibb.co/pR1mvxX
    My configuration:
    https://ibb.co/tchYLq9
    in reply to: About Elastic Report Month Period #8546
    kcks66
    Hi Mikhail,
    Noted with thx.
    in reply to: About Elastic Report Month Period #8515
    kcks66
    Hi Mikhail,
    I am now working on yearly report. Is the Elastic Report able to generate something like this example?
    Date Total Usage (kWh)
    01/01/2017 123456789
    01/01/2018 123456789
    01/01/2019 123456789
    01/01/2020 123456789
    01/01/2021 123456789
    in reply to: Registration Telegram driver #8275
    kcks66
    Hi Mikhail,
    I restarted the service Instance status but still cannot get computer code. And I have no idea where to find the communication line log.
    By the way, I found this error log:
    2021-02-09 10:26:29 <MAC-WIN10><SYSTEM><ACT> ScadaCommService 5.2.1.2 is started
    2021-02-09 10:26:29 <MAC-WIN10><SYSTEM><ACT> Load device library: KpModbus.dll
    2021-02-09 10:26:29 <MAC-WIN10><SYSTEM><ACT> Load device library: KpTelegram.dll
    2021-02-09 10:26:29 <MAC-WIN10><SYSTEM><EXC> Error creating communication line 4:
    Scada.ScadaException: Error getting device logic type from the library KpTelegram.dll: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information. —> System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information.
    at System.Reflection.RuntimeAssembly.nLoadFile(String path, Evidence evidence)
    at System.Reflection.Assembly.LoadFile(String path)
    at Scada.Comm.Devices.KPFactory.GetKPLogic(String kpDir, String dllName, Int32 kpNum)
    at Scada.Comm.Engine.CommLine.CreateKPLogic(Int32 kpNum, String dllName, AppDirs appDirs, Dictionary`2 kpTypes, Log appLog)
    at Scada.Comm.Engine.CommLine.Create(CommLine commLineSett, CommonParams commonParams, AppDirs appDirs, PassCmdDelegate passCmd, Dictionary`2 kpTypes, Log appLog)
    at Scada.Comm.Engine.Manager.CreateCommLine(CommLine commLineSett)
    2021-02-09 10:26:30 <MAC-WIN10><SYSTEM><ACT> Connect to SCADA-Server “localhost”
    2021-02-09 10:26:31 <MAC-WIN10><SYSTEM><ACT> Start communication lines
    2021-02-09 10:26:31 <MAC-WIN10><SYSTEM><ACT> Start receiving commands
    Telegram driver:
    https://ibb.co/CVD9Cg7
    in reply to: Static text vertical orientation #8242
    kcks66
    Hi Mikhail,
    Noted with thanks.
    in reply to: About Elastic Report Month Period #8241
    kcks66
    Hi Mikhail,
    I changed to 12 and it worked.
    in reply to: About Elastic Report Month Period #8231
    kcks66
    Hi Mikhail,
    I set it to 1, but I still having the same error.
    in reply to: About Elastic Report Month Period #8212
    kcks66
    Hi Mikhail,
    The error was the same if I selected Excel or PDF. The error information from the log:
    2021-01-31 21:11:45 <MAC-WIN10><DefaultAppPool><ACT> Generate “Elastic report” report by the user admin
    2021-01-31 21:11:45 <MAC-WIN10><DefaultAppPool><EXC> Application error:
    System.ArgumentOutOfRangeException: Hour, Minute, and Second parameters describe an un-representable DateTime.
    at System.DateTime.TimeToTicks(Int32 hour, Int32 minute, Int32 second)
    at Scada.Web.Plugins.ElasticReport.Model.Builder.DocContext.InitWorkPeriod(DateTime startDate, DateTime endDate, Boolean prependDay, Boolean appendDay)
    at Scada.Web.Plugins.ElasticReport.Model.Builder.DocBuilder.GenerateDocument(ElasticRepConfig config, DateTime startDate, DateTime endDate, BuildOptions buildOptions)
    at Scada.Web.Plugins.ElasticReport.ElasticRepHtmlBuilder.GenerateHtml(ElasticRepConfig config, DateTime startDate, DateTime endDate, String& title)
    at Scada.Web.Plugins.ElasticReport.WFrmElasticRepHtmlOut.Page_Load(Object sender, EventArgs e)
    at System.Web.UI.Control.OnLoad(EventArgs e)
    at System.Web.UI.Control.LoadRecursive()
    at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
    Page: http://localhost/Scada/plugins/ElasticReport/ElasticRepHtmlOut.aspx?reportID=50&startDate=2021-01-01&endDate=2021-01-01
    User: admin
    in reply to: Get data from excel into DAT files #8091
    kcks66
    Hi Mikhail,
    Yes. Thank you.
    in reply to: Get data from excel into DAT files #8079
    kcks66
    Hi Mikhail & Manjey73,
    I have no knowledge on the “Integration with Rapid SCADA” parts. However, I managed to manual generate value in new Achieve files.
    The setting is from the Saving Parameters. I increased the default 365 days to more, then it worked.
    https://ibb.co/bF7zmyX
    https://ibb.co/qmXqgkq
    • This reply was modified 5 years, 9 months ago by kcks66.
    in reply to: Get data from excel into DAT files #8056
    kcks66
    Hi Manjey73,
    Can you explain more about the API.
