scadakid
  • in reply to: OPC on Remote PC #7194
    scadakid
    Hi Mikhail,
    I can browse the remote OPC server now. I have’t checked the point values yet. I will update here. Thanks.
    in reply to: OPC on Remote PC #7183
    scadakid
    Hi Mikhail,
    I was able to create new deployment profile for the 2nd instance.
    in reply to: OPC on Remote PC #7167
    scadakid
    Hi Mikhail,
    Thanks for your reply.
    IP address = IP of the remote server
    Username = ScadaAdmin
    Password = 12345
    What should be the Secret key?
    in reply to: OPC on Remote PC #7162
    scadakid
    I have done the following steps.
    1) install Agent and Communicator on remote PC in which OPC server is installed (OK)
    2) communicator on the remote PC refer to main rapid scada server (OK)
    3) create second instance in main rapid scada server (FAIL)
    what setting should be in second instance?
    4) create new deployment for second instance (FAIL),
    I have gone through the following two topics also. I still can’t get the whole picture exactly.
    OPC on network
    Remote Communicator
    • This reply was modified 6 years, 2 months ago by scadakid.
    in reply to: OPC on Remote PC #7160
    scadakid
    I tried to create it.
    OPC3
    OPC4
    in reply to: OPC on Remote PC #7156
    scadakid
    OPC2
    in reply to: OPC on Remote PC #7151
    scadakid
    When I upload, I get this error.
    [url=https://ibb.co/XZqywdS][img]https://i.ibb.co/gMxvnXz/OPC2.png[/img][/url]
    in reply to: OPC on Remote PC #7148
    scadakid
    I created new instance as below. What is the next step?
    OPC Instance
    in reply to: OPC on Remote PC #7147
    scadakid
    Hi Mikhail,
    Below is the ScadaCom log from remote PC.
    Rapid Scada server IP is 192.168.0.134. Is it correct configuration?
    2020-08-12 23:01:59 <WIN7-PC><SYSTEM><ERR> Unable to connect to SCADA-Server. Try again.
    2020-08-12 23:02:00 <WIN7-PC><SYSTEM><ACT> Connect to SCADA-Server “192.168.0.134”
    2020-08-12 23:02:53 <WIN7-PC><SYSTEM><ACT> Receiving commands aborted
    2020-08-12 23:02:53 <WIN7-PC><SYSTEM><ACT> Stop communication lines
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> Disconnect from SCADA-Server
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> ScadaCommService is stopped
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> ScadaCommService 5.2.1.1 is started
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> Load device library: KpModbus.dll
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> Load device library: KpOpc.dll
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> Load device library: KpSms.dll
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> Load device library: KpEmail.dll
    2020-08-12 23:02:58 <WIN7-PC><SYSTEM><ACT> Load device library: KpSnmp.dll
    2020-08-12 23:02:59 <WIN7-PC><SYSTEM><ACT> Connect to SCADA-Server “192.168.0.134”
    2020-08-12 23:02:59 <WIN7-PC><SYSTEM><ACT> Start communication lines
    2020-08-12 23:02:59 <WIN7-PC><SYSTEM><ACT> Start receiving commands
