abedi
  • in reply to: Try to integrate with IED using DNP3 Protocol #7047
    abedi
    What are the conditions of sponsorship?
    in reply to: Error state on device #7044
    abedi
    in reply to: Error state on device #7041
    abedi
    The screen shot image link:
    https://1drv.ms/u/s!ArUszYM3qWAukCmmsWVLtkTl311D
    in reply to: Error state on device #7029
    abedi
    I tried to check the settings.
    The new communication line log:
    2020-07-16 14:07:56 Establish a TCP connection with 172.27.1.211:502
    2020-07-16 14:07:56 Communication session with the Device 1 “wp”, type: KpModbus, address: 2, call number: 172.27.1.211
    Request element group “g1”
    Send (12): 00 55 00 00 00 06 02 03 00 00 00 01
    2020-07-16 14:07:56 Error communicating with Device 1 “wp”: Error reading data: Timeout can be only be set to ‘System.Threading.Timeout.Infinite’ or a value > 0.
    Parameter name: value
    2020-07-16 14:07:56 Disconnect from 172.27.1.211
    in reply to: Error state on device #7028
    abedi
    Thanks for the reply. Do you have any idea that how I can check the PLC? there is no special setting in it. Or shall I change the port? or sth else?
    Thanks again.
    in reply to: Error state on device #7019
    abedi
    2020-07-15 09:16:09 Establish a TCP connection with 172.27.1.210:502
    Error establishing TCP connection: No connection could be made because the target machine actively refused it 172.27.1.210:502
    2020-07-15 09:16:10 Unable to communicate with Device 1 “wp” because connection is not established
    2020-07-15 09:16:11 Attempt to establish TCP connection can not be earlier than 5 seconds after the previous.
    2020-07-15 09:16:11 Unable to communicate with Device 1 “wp” because connection is not established
    explanation: server ip: 172.27.1.210
    cpu LAN port ip: 172.27.1.211
