christian.beatriz
ParticipantGood news! it worked, well not immediately, First I executed the commands and the systems says i don’t have administrative rights to run the tool, but that was not true cause i do have the rights, even so, i checked for the correct users rights and they were wright.
So, after some efforts, i went to: start>Control Panel>System and Security> Action Center>Choose Your UAC Level -Set this to Never Notify- (A restart was Required)
Then i tried again as i was told and this time it executed fine. Now the rapidscada demo is working fine.
Thanks a lot!!christian.beatriz
ParticipantShows up the 404 Error as i show here:
<img src="<img src=”https://i.ibb.co/tsWrhR3/red-request-link-browser-response.jpg” alt=”red-request-link-browser-response” border=”0″ />” alt=”Response” />christian.beatriz
ParticipantGot it, but those features were both already off as the installation instruccion video says. Now i turned then on both and it got worse, as you can see here: <img src="<img src=”https://i.ibb.co/Y04zwJD/Server-error.jpg” alt=”Server-error” border=”0″ />” alt=”Server Error” />
Then i turned on only the “Windows Communication Foundation HTTP Activation” and i had this same result
Then, i turned on only the “Windows Communication Foundation Non-HTTP Activation” and i went back to the first scenario about the “Error updating current data”christian.beatriz
Participant<img src="<img src=”https://i.ibb.co/RSBZxPZ/Console-tab.jpg” alt=”Console-tab” border=”0″ />” alt=”Console error messages” />
christian.beatriz
Well I have download and installed the “scada_5.8.0_full_en” files, but when I looked into the administrator app and goes to the “help” tap and click at “about” it says “administrator version 5.5.2.0”, so I don’nt know if that version is 5.8.0 or 5.5.2..?
I have installed this software in two computers, one with windows 10, 64 bits and works fine, but in the computer with windows 7, 32 bits, does not and shows the issue I wrote before -
