OtavioF
ParticipantHello, Mikhail.
On the dll file properties, version is 1.0.0.0, last modified at july 28, 2020.
Bigger part of the configuration file, excluding MQTT server username and password:
<?xml version="1.0" encoding="utf-8"?> <DevTemplate> <MqttParams Hostname="node02.myqtthub.com" ClientID="---" Port="1883" UserName="otaviofolharini" Password="---"/> <RapSrvCnf ServerHost="127.0.0.1" ServerPort="10001" ServerUser="ScadaComm" ServerPwd="12345"/> <MqttSubTopics> <Topic TopicName="/mesparam1" QosLevel="0" NumCnl="666"/> </MqttSubTopics> <MqttPubTopics> </MqttPubTopics> <MqttPubCmds> </MqttPubCmds> <MqttSubCmds> </MqttSubCmds> <MqttSubJSs> </MqttSubJSs> </DevTemplate>The communication line log:
2022-08-22 08:52:39 Initialize communication line 10 "MQTT" Send packet Send packet Connection established 2022-08-22 08:52:42 Start communication line 10 "MQTT" 2022-08-22 08:52:42 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Send packet 2022-08-22 08:52:43 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Receive packet 2022-08-22 08:52:43 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Receive packet 2022-08-22 08:52:44 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Receive packet 2022-08-22 08:52:44 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Send packet 2022-08-22 08:52:44 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Send packet 2022-08-22 08:52:45 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Send packet 2022-08-22 08:52:45 Communication session with the Device 5 "MQTTCascata", type: KpMqtt Receive packet [...]Device info:
Device 5 "MQTTCascata" ---------------------- DLL : KpMqtt State : normal Comm. session : 22/08/2022 08:54:30 Command : time is undefined Comm. sessions (total / errors) : 295 / 0 Commands (total / errors) : 0 / 0 Requests (total / errors) : 146 / 0 Current device tags data +--------+------------+-------+---------+ | Signal | Name | Value | Channel | +--------+------------+-------+---------+ | ******** GroupMQTT ****************** | +--------+------------+-------+---------+ | 1 | /mesparam1 | --- | 666 | +--------+------------+-------+---------+ No archive data No events No commandsHere is a print from MyQtt Web Interface, that allowes me to publish messages to topics.
https://imgur.com/W8XuWXnI’ll give a try on the new MQTT driver. Hope it works!
Thank you.OtavioF
ParticipantHi cooldjmc
If you’re running on Windows, run the curl command over Command Prompt (cmd.exe) using administrator rights.
OtavioF
ParticipantHello!
The time format was indeed wrong. However, it was easier (at least for me) to change the expected input format in GrafanaDataProvider than change it on the Grafana plugin. I’m more familiar to C# than go-lang.
In the other hand, now GrafanaDataProvider doesn’t work when receiving requests from the original Simple Json Database. I’ll make some improvements as soon as I can.
Thank you for all your support, Mikhail.
OtavioF
This seems to be something with the date format that the datasource sends to GrafanaDataProvider.
On GrafanaDataProvider, the grafanaArg.range.from value is always 01/01/0001 00:00:00. When it’s converted to Unix in TrendsController.cs (line 227), it gets a negative value, which is expected.
Tomorrow begins Christmas break on my company, so I’ll be back on this issue by January 4th.
Thank you for all your attention. I hope I’ll comeback with a solution in mind.
Happy New Year, Mikhail.
OtavioF
The description of the exception is:
Newtonsoft.Json.JsonReaderException: 'Could not convert string to DateTime: 1608121200227. Path 'range.to', line 1, position 53.'Using the PDB and source code of the Newtonsoft, Visual Studion points the error occurring in this function (marked with some “<<<” on the line)
internal DateTime? ReadDateTimeString(string s) { if (string.IsNullOrEmpty(s)) { SetToken(JsonToken.Null, null, false); return null; } if (DateTimeUtils.TryParseDateTime(s, DateTimeZoneHandling, _dateFormatString, Culture, out DateTime dt)) { dt = DateTimeUtils.EnsureDateTime(dt, DateTimeZoneHandling); SetToken(JsonToken.Date, dt, false); return dt; } if (DateTime.TryParse(s, Culture, DateTimeStyles.RoundtripKind, out dt)) { dt = DateTimeUtils.EnsureDateTime(dt, DateTimeZoneHandling); SetToken(JsonToken.Date, dt, false); return dt; <<<<<<<<-------- } throw JsonReaderException.Create(this, "Could not convert string to DateTime: {0}.".FormatWith(CultureInfo.InvariantCulture, s)); }As requested, the exception stack is as it follows:
> Newtonsoft.Json.dll!Newtonsoft.Json.JsonReader.ReadDateTimeString(string s) Line 856 C# Newtonsoft.Json.dll!Newtonsoft.Json.JsonTextReader.FinishReadQuotedStringValue(Newtonsoft.Json.ReadType readType) Line 729 C# Newtonsoft.Json.dll!Newtonsoft.Json.JsonTextReader.ReadAsDateTime() Line 467 C# Newtonsoft.Json.dll!Newtonsoft.Json.JsonReader.ReadForType(Newtonsoft.Json.Serialization.JsonContract contract, bool hasConverter) Line 1217 C# Newtonsoft.Json.dll!Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(object newObject, Newtonsoft.Json.JsonReader reader, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, string id) Line 2378 C# Newtonsoft.Json.dll!Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerMember, object existingValue) Line 485 C# Newtonsoft.Json.dll!Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(Newtonsoft.Json.Serialization.JsonProperty property, Newtonsoft.Json.JsonConverter propertyConverter, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerProperty, Newtonsoft.Json.JsonReader reader, object target) Line 1004 C# Newtonsoft.Json.dll!Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(object newObject, Newtonsoft.Json.JsonReader reader, Newtonsoft.Json.Serialization.JsonObjectContract contract, Newtonsoft.Json.Serialization.JsonProperty member, string id) Line 2331 C# Newtonsoft.Json.dll!Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(Newtonsoft.Json.JsonReader reader, System.Type objectType, Newtonsoft.Json.Serialization.JsonContract contract, Newtonsoft.Json.Serialization.JsonProperty member, Newtonsoft.Json.Serialization.JsonContainerContract containerContract, Newtonsoft.Json.Serialization.JsonProperty containerMember, object existingValue) Line 485 C# Newtonsoft.Json.dll!Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(Newtonsoft.Json.JsonReader reader, System.Type objectType, bool checkAdditionalContent) Line 167 C# Newtonsoft.Json.dll!Newtonsoft.Json.JsonSerializer.DeserializeInternal(Newtonsoft.Json.JsonReader reader, System.Type objectType) Line 901 C# System.Net.Http.Formatting.dll!System.Net.Http.Formatting.BaseJsonMediaTypeFormatter.ReadFromStream(System.Type type, System.IO.Stream readStream, System.Text.Encoding effectiveEncoding, System.Net.Http.Formatting.IFormatterLogger formatterLogger) Unknown System.Net.Http.Formatting.dll!System.Net.Http.Formatting.BaseJsonMediaTypeFormatter.ReadFromStream(System.Type type, System.IO.Stream readStream, System.Net.Http.HttpContent content, System.Net.Http.Formatting.IFormatterLogger formatterLogger) Unknown System.Net.Http.Formatting.dll!System.Net.Http.Formatting.BaseJsonMediaTypeFormatter.ReadFromStreamAsync(System.Type type, System.IO.Stream readStream, System.Net.Http.HttpContent content, System.Net.Http.Formatting.IFormatterLogger formatterLogger) Unknown System.Net.Http.Formatting.dll!System.Net.Http.Formatting.MediaTypeFormatter.ReadFromStreamAsync(System.Type type, System.IO.Stream readStream, System.Net.Http.HttpContent content, System.Net.Http.Formatting.IFormatterLogger formatterLogger, System.Threading.CancellationToken cancellationToken) Unknown System.Net.Http.Formatting.dll!System.Net.Http.HttpContentExtensions.ReadAsAsyncCore<object>(System.Net.Http.HttpContent content, System.Type type, System.Net.Http.Formatting.IFormatterLogger formatterLogger, System.Net.Http.Formatting.MediaTypeFormatter formatter, System.Threading.CancellationToken cancellationToken) Unknown System.Net.Http.Formatting.dll!System.Net.Http.HttpContentExtensions.ReadAsAsync<object>(System.Net.Http.HttpContent content, System.Type type, System.Collections.Generic.IEnumerable<System.Net.Http.Formatting.MediaTypeFormatter> formatters, System.Net.Http.Formatting.IFormatterLogger formatterLogger, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.ModelBinding.FormatterParameterBinding.ReadContentAsync(System.Net.Http.HttpRequestMessage request, System.Type type, System.Collections.Generic.IEnumerable<System.Net.Http.Formatting.MediaTypeFormatter> formatters, System.Net.Http.Formatting.IFormatterLogger formatterLogger, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.ModelBinding.FormatterParameterBinding.ReadContentAsync(System.Net.Http.HttpRequestMessage request, System.Type type, System.Collections.Generic.IEnumerable<System.Net.Http.Formatting.MediaTypeFormatter> formatters, System.Net.Http.Formatting.IFormatterLogger formatterLogger) Unknown System.Web.Http.dll!System.Web.Http.ModelBinding.FormatterParameterBinding.ExecuteBindingAsyncCore(System.Web.Http.Metadata.ModelMetadataProvider metadataProvider, System.Web.Http.Controllers.HttpActionContext actionContext, System.Web.Http.Controllers.HttpParameterDescriptor paramFromBody, System.Type type, System.Net.Http.HttpRequestMessage request, System.Net.Http.Formatting.IFormatterLogger formatterLogger, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.ModelBinding.FormatterParameterBinding.ExecuteBindingAsync(System.Web.Http.Metadata.ModelMetadataProvider metadataProvider, System.Web.Http.Controllers.HttpActionContext actionContext, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.Controllers.HttpActionBinding.ExecuteBindingAsyncCore(System.Web.Http.Controllers.HttpActionContext actionContext, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.Controllers.HttpActionBinding.ExecuteBindingAsync(System.Web.Http.Controllers.HttpActionContext actionContext, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.Controllers.ActionFilterResult.ExecuteAsync(System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.ApiController.ExecuteAsync(System.Web.Http.Controllers.HttpControllerContext controllerContext, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.Dispatcher.HttpControllerDispatcher.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) Unknown System.Net.Http.dll!System.Net.Http.HttpMessageInvoker.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.Dispatcher.HttpRoutingDispatcher.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) Unknown System.Net.Http.dll!System.Net.Http.DelegatingHandler.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.dll!System.Web.Http.HttpServer.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) Unknown System.Net.Http.dll!System.Net.Http.HttpMessageInvoker.SendAsync(System.Net.Http.HttpRequestMessage request, System.Threading.CancellationToken cancellationToken) Unknown System.Web.Http.WebHost.dll!System.Web.Http.WebHost.HttpControllerHandler.ProcessRequestAsyncCore(System.Web.HttpContextBase contextBase) Unknown System.Web.dll!System.Web.TaskAsyncHelper.BeginTask(System.Func<System.Threading.Tasks.Task> taskFunc, System.AsyncCallback callback, object state) Unknown System.Web.dll!System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() Unknown System.Web.dll!System.Web.HttpApplication.ExecuteStepImpl(System.Web.HttpApplication.IExecutionStep step) Unknown System.Web.dll!System.Web.HttpApplication.ExecuteStep(System.Web.HttpApplication.IExecutionStep step, ref bool completedSynchronously) Unknown System.Web.dll!System.Web.HttpApplication.PipelineStepManager.ResumeSteps(System.Exception error) Unknown System.Web.dll!System.Web.HttpApplication.BeginProcessRequestNotification(System.Web.HttpContext context, System.AsyncCallback cb) Unknown System.Web.dll!System.Web.HttpRuntime.ProcessRequestNotificationPrivate(System.Web.Hosting.IIS7WorkerRequest wr, System.Web.HttpContext context) Unknown System.Web.dll!System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(System.IntPtr rootedObjectsPointer, System.IntPtr nativeRequestContext, System.IntPtr moduleData, int flags) Unknown System.Web.dll!System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(System.IntPtr rootedObjectsPointer, System.IntPtr nativeRequestContext, System.IntPtr moduleData, int flags) Unknown [Native to Managed Transition] [Managed to Native Transition] System.Web.dll!System.Web.Hosting.PipelineRuntime.ProcessRequestNotificationHelper(System.IntPtr rootedObjectsPointer, System.IntPtr nativeRequestContext, System.IntPtr moduleData, int flags) Unknown System.Web.dll!System.Web.Hosting.PipelineRuntime.ProcessRequestNotification(System.IntPtr rootedObjectsPointer, System.IntPtr nativeRequestContext, System.IntPtr moduleData, int flags) Unknown [AppDomain Transition]OtavioF
I disabled “Just My Code” on Debug Options and managed to get a few more info.Now I get this messages on every Grafana’s refresh:
Exception thrown: 'Newtonsoft.Json.JsonReaderException' in Newtonsoft.Json.dll Exception thrown: 'Newtonsoft.Json.JsonReaderException' in Newtonsoft.Json.dll Exception thrown: 'Scada.ScadaException' in ScadaData.dllThe soap opera continues…
OtavioF
I’m getting no output.I’ve compiled Log(Release) > ScadaData(Release) > GrafanaDataProvider(Debug), attached to process the w3wp.exe but I’m getting no output. Am I missing something?
OtavioF
ParticipantHello!
Could you describe how to debug the GrafanaDataProvider on Visual Studio? I got it running on my PC, Google’d some how-to but no success.
OtavioF
ParticipantSomething to think about: I’ve tested the database with the Fake Simple Json Datasource and its working flawlessly.
OtavioF
I don’t have Visual Studio on this PC yet. After I install it, I’ll try to debug and will get back with updates.Thank you for all your help, Mikhail
OtavioF
ParticipantI hope flooding with updates on this matter is not against the rules of the forum. hehehe
After changing RapidScada’s port to 10001 (which includes ScadaWeb, GrafanaDataProvider and within Administrator), Grafana is finally receiving data!
However, it’s fetching the wrong minute .dat file.
2020-11-05 15:45:40 Receive input channel 298 trend from SCADA-Server. File: m010101.datThe fetched file should be m201105.dat
OtavioF
ParticipantIndeed there was a conflict with the TCP ports. Now I’m able to access the Web application and there’s no error whatsoever on RapidScada.
Now I’m trying to display the values on Grafana. Maybe now it’s the problem that you mentioned before, about request’s format to GrafanaDataProvider.
I’ll send updates when there is any.
OtavioF
ParticipantHello.
I think I found the problem and its on the TCP port. The plugin after build generates an .exe file that, when its running, I ran the CurrPorts (software to monitor the TCP/UDP ports) and the plugin’s exe is using the TCP port 10000.
I’ll have a look at the source code to see if I can change it without messing with the RapidScada. If I can’t find it, I’ll change RapidScada’s settings and see if it works.
I’ll report back with news (let’s hope they’re good ones)
OtavioF
ParticipantHi!
I’m not the author of this plugin. I believe the way it works should be close to the original Simple Json database used to develop the GrafanaDataProvider app. The difference is that this plugin has support for alerts and annotations, so it’s a “backend” database plugin.
I think I’ll have to analyze the source code of the plugin and try to identify what’s causing the conflict.
OtavioF
ParticipantHello!
The SCADA-Server log at the same period of time is like this:
2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> ScadaServerService 5.1.2.1 is started 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Check the existence of the data directories is completed successfully 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Check the existence of the configuration database files is completed successfully 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Input channels are read from the configuration database. Active channel count: 81 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Ouput channels are read from the configuration database 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Users are read from the configuration database 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Formulas are read from the configuration database 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> The formulas source code has been compiled 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Connection listener is started 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Start server 2020-10-21 16:39:44 <ENGENHARIA-03><SISTEMA><ACT> Current data are loadedIt seems that there is nothing wrong with Server. When checking Instance Status, Server status its “Normal”, but Communicator appears “Error”.
