tshoman
ParticipantHi Mikhail
Everything works now ! . Thanks for your help.
Regards.
tshoman
I followed all the steps above:
1) copied secret key from /opt/scada/ScadaAgent/Config/ScadaAgentConfig.xml and pasted it in profile.
2) Generated (exported) user.dat from Scada Admin in Windows and saved it to Rpi in /opt/scada/BaseDAT
I still can’t login and the error generated now is Insuffient rightds. I’m logging in with default login for scada ( i.e admin ) which I have not changed.
The error log is pasted below. Please advice me how to proceed. Regards.
2020-04-05 18:49:11 <raspberrypi><root><ACT> Agent 5.0.2.0 started
2020-04-05 18:49:15 <raspberrypi><root><ACT> WCF service is started at http://localhost:10002/ScadaAgent/ScadaAgentSvc/
2020-04-05 18:49:15 <raspberrypi><root><ACT> Start logic processing
2020-04-06 16:20:01 <raspberrypi><root><ACT> Session with ID -5008235423191582206 created
2020-04-06 16:20:02 <raspberrypi><root><ERR> User pi failed validation to connect to Default – Invalid username or password
2020-04-06 16:20:32 <raspberrypi><root><ACT> Session with ID 5394815069474664172 created
2020-04-06 16:20:32 <raspberrypi><root><ERR> User admin failed validation to connect to Default – Insufficient rights
2020-04-06 16:20:41 <raspberrypi><root><ACT> Session with ID -3896198060526525543 created
2020-04-06 16:20:41 <raspberrypi><root><ERR> User admin failed validation to connect to Default – Insufficient rights
2020-04-06 16:25:36 <raspberrypi><root><ACT> Session with ID -329630652190660358 created
2020-04-06 16:25:36 <raspberrypi><root><ERR> User admin failed validation to connect to Default – Insufficient rights
2020-04-06 16:27:34 <raspberrypi><root><ACT> WCF service is stopped
2020-04-06 16:27:34 <raspberrypi><root><ACT> All temporary files deleted
2020-04-06 16:27:34 <raspberrypi><root><ACT> Logic processing is stopped
2020-04-06 16:27:34 <raspberrypi><root><ACT> Agent is stopped
2020-04-06 16:27:51 <raspberrypi><root><ACT> Agent 5.0.2.0 started
2020-04-06 16:27:53 <raspberrypi><root><ACT> WCF service is started at http://localhost:10002/ScadaAgent/ScadaAgentSvc/
2020-04-06 16:27:53 <raspberrypi><root><ACT> Start logic processing
2020-04-06 16:28:47 <raspberrypi><root><ACT> Session with ID 468270691277926380 created
2020-04-06 16:28:48 <raspberrypi><root><ERR> User admin failed validation to connect to Default – Insufficient rightstshoman
ParticipantThanks for response Mikhail
I managed to create the deployment profile. However, upon testing there is an error – Unable to Login-Invalid Usernane or password. I tried 2 different username/password 1) default login for scada (admin) and 2) default for Rpi (pi) both cannot login. I also left the port number as is (10002).
As for the secret key, should I click to generate one automatically or I can type my own key.
Anything I’m doing wrong.
Regards.
