38368423
Viewing 15 posts - 1 through 15 (of 15 total)
  • 38368423
    sorry, It was my mistake.
    in reply to: how to configure modbus #17312
    38368423
    There was an error in my description. The actual situation is as follows: my device cannot access the internet, and it supports the Modbus RTU protocol. I have installed another networked device on this equipment, which is custom-developed. It can connect to my cloud platform and is also connected to the non-internet-enabled device via 485. When the networked device connects to the cloud platform, it sends a hello packet.
    in reply to: how to configure modbus #17310
    38368423
    I noticed that TcpServerChannelLogic has implemented hello packet handling, but it might not be able to collect a complete hello packet.
    in reply to: how to configure modbus #17309
    38368423
    it is generated by a router
    in reply to: Event marker not found #16382
    38368423
    I have sent the faulty event file to your email address info@rapidscada.org with the subject “Event marker not found.” This issue not only causes the event file to become corrupted but also affects the files in the min, hour, and cur directories.
    in reply to: Event marker not found #16362
    38368423
    This scenario is easy to reproduce. The reproduction conditions are as follows:
    1、You have a large amount of data that needs to be read and recorded.
    2、You configure alarms for these data channels.
    3、Frequent power outages and restarts occur.
    in reply to: Event marker not found #16355
    38368423
    This issue is quite serious as it has caused the data files and event files to become unreadable. Is there a timeline for the fix?
    in reply to: Event marker not found #16332
    38368423
    It is installed on an Ubuntu system. Personally, I find event loss acceptable, but I cannot accept file corruption. The problem now is that after corruption occurs, no more events are generated, and there is no automatic recovery mechanism.
    in reply to: Event marker not found #16324
    38368423
    My device operates in an environment prone to power outages. What solutions are available?
    in reply to: Event marker not found #16315
    38368423
    yes,file is corrupted,Why do files often get corrupted, and how can this be avoided?
    in reply to: how to modify the string through send command. #16210
    38368423
    length of string is great than 24
    in reply to: How to send a string in an input channel through MQTT #15937
    38368423
    Do you have any suggestions for extending MQTT driver support for strings
    in reply to: How to send a string in an input channel through MQTT #15936
    38368423
    How can I implement it? Can you give me a demonstration
    in reply to: How to control LED flashing through the digital output(DO) port #15840
    38368423
    yes, I have.
    in reply to: Compile rapidscada #6326
    38368423
    hi,
    Error cs1503:Parameter 2: cannot convert from “SCADA. Agent. Serviceapp” to “SCADA. Agent. Connector. Agentsvcref. Serviceapp”
    Error cs1503: parameter 2: cannot convert from “SCADA. Agent. Relpath” to “SCADA. Agent. Connector. Agentsvcref. Relpath”
    and so on
