wonderwareguru
  • in reply to: MQTT in-depth Installation Help #6130
    wonderwareguru
    Thanks a lot for your time GreenFoxx… I’ll play around with your guide tonight and reply back.
    Thank you again
    in reply to: MQTT in-depth Installation Help #6121
    wonderwareguru
    Hi GreenFoxx,
    I appreciate your reply. I moved the files to their appropriate directories; however, I’m still trying to figure out how set everything up in Rapdiscada.
    The following is a good start:
    https://github.com/RapidScada/scada-community/blob/master/Drivers/KpMqtt/README-EN.md
    unfortunately, it still doesn’t help setup rapidscada. I can create a communication line… but the instructions say to link the mqtt configuration file. How is that done?
    I would really appreciate a step by step setup of rapidscada with MQTT. It’s easy for the developer that designed it, but not the end user.
    Thank you
