chriskkelly
Viewing 15 posts - 1 through 15 (of 15 total)
  • in reply to: Installation of Webstation plugins #6181
    chriskkelly
    cheers, that seemed to have sorted it.
    in reply to: Installation of Webstation plugins #6174
    chriskkelly
    https://drive.google.com/file/d/1MU2vOKd3ObtIPPvc4iA8CHWXbDDyAbtj/preview
    • This reply was modified 6 years, 11 months ago by Mikhail.
    in reply to: Installation of Webstation plugins #6173
    chriskkelly
    here is a screenshot…
    Screenshot
    • This reply was modified 6 years, 11 months ago by chriskkelly.
    in reply to: Installation of Webstation plugins #6163
    chriskkelly
    Nope even with user permissions set to max on all users still getting this error
    it seems to be able to load basic components fine.
    in reply to: Installation of Webstation plugins #6159
    chriskkelly
    2019-12-06 20:38:27 <WIN-E67EIJHEJ5K><Administrator><ACT> Initialize common data of Scheme Editor
    2019-12-06 20:38:27 <WIN-E67EIJHEJ5K><Administrator><ACT> Load components from files
    2019-12-06 20:38:27 <WIN-E67EIJHEJ5K><Administrator><ACT> Components are loaded from the file C:\SCADA\ScadaWeb\bin\PlgSchBasicComp.dll
    2019-12-06 20:38:27 <WIN-E67EIJHEJ5K><Administrator><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll:
    Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
    2019-12-06 20:38:27 <WIN-E67EIJHEJ5K><Administrator><ACT> WCF service is started
    2019-12-06 20:38:57 <WIN-E67EIJHEJ5K><Administrator><ACT> WCF service is stopped
    2019-12-06 20:38:57 <WIN-E67EIJHEJ5K><Administrator><ACT> Scheme Editor is shutdown
    in reply to: Installation of Webstation plugins #6158
    chriskkelly
    2019-12-04 21:49:17 <WIN-E67EIJHEJ5K><Administrator><ACT> Initialize common data of Scheme Editor
    2019-12-04 21:49:17 <WIN-E67EIJHEJ5K><Administrator><ACT> Load components from files
    2019-12-04 21:49:17 <WIN-E67EIJHEJ5K><Administrator><ACT> Components are loaded from the file C:\SCADA\ScadaWeb\bin\PlgSchBasicComp.dll
    2019-12-04 21:49:18 <WIN-E67EIJHEJ5K><Administrator><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll:
    2019-12-04 21:49:18 <WIN-E67EIJHEJ5K><Administrator><ACT> WCF service is started
    2019-12-06 20:32:21 <WIN-E67EIJHEJ5K><Administrator><ACT> WCF service is stopped
    2019-12-06 20:32:21 <WIN-E67EIJHEJ5K><Administrator><ACT> Scheme Editor is shutdown
    in reply to: Installation of Webstation plugins #6155
    chriskkelly
    Any of extra components in scheme editor despite downloading it to my project.
    in reply to: Installation of Webstation plugins #6151
    chriskkelly
    any ideas why they are not showing in scheme editor?
    in reply to: Installation of Webstation plugins #6145
    chriskkelly
    downloaded and have PlgSchExtraComp_Reg.xml but can’t see them in scheme editor.
    in reply to: Installation of Webstation plugins #6143
    chriskkelly
    what do you mean how do i download web application settings?
    in reply to: Installation of Webstation plugins #6140
    chriskkelly
    Hi I installed extra scheme plugins and enable it in plugins but everytime i logout of rapid scada or restart pc it disables it requiring me to activate it again. It is also not showing in scheme editor. I copied the required .dll in to scada web bin and web files into webscada plugins file.
    in reply to: MQTT in-depth Installation Help #6129
    chriskkelly
    cheers, still confused where two place the two directories MQTTCore and Properties
    in reply to: MQTT in-depth Installation Help #6123
    chriskkelly
    I am having similar issues where should i place MQTTCore and Properties folders for mqtt installation?
    in reply to: Scheme Loading Failed after installing #6122
    chriskkelly
    I found an issue and reinstalled net framework 4.6 and re enabled it.
    in reply to: Scheme Loading Failed after installing #6100
    chriskkelly
    yes they match followed the video
