sokol
Participantok, many thanks!
sokol
Participanthi, new attempt:
i done the followig operations:
– uninstall
– install new
log says:Install Communicator application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaComm.zip
Install service ScadaCommService
Installation of Communicator application has completed successfullyCheck the configuration of Internet Information Services (IIS)
Go to
Control Panel > Programs > Turn Windows features on or off
and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
whereas the components for .NET Framework 3.5 are switched off
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaWeb.zip
Selected application pool: DefaultAppPool
Register web application Scada
Create shortcut Webstation
Installation of Webstation application has completed successfullyInstall Agent application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaAgent.zip
Install service ScadaAgentService
Installation of Agent application has completed successfullyInstall Administrator application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaAdmin.zip
Create shortcut Administrator
Installation of Administrator application has completed successfullyInstall Scheme Editor application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaSchemeEditor.zip
Installation of Scheme Editor application has completed successfullyInstall Table Editor application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaTableEditor.zip
Installation of Table Editor application has completed successfullyInstallation has completed successfully
Please restart the computeri get an error by trying to create a new Modbus KP:
“Error getting device interface type from the library
KpModbusSlave.dll: The System do not can find the file
(0x80070002)sokol
ParticipantHi, nearly the same Problem:
Trying to install latest RapidScada 5.7.1 to Windows10 Pro 64bit with latest updates.
Installation gives notes and errors:Rapid SCADA 5.7.1 Installation
Check version of Microsoft .NET FrameworkInstall Server application
Unzip files from C:\Users\ER\Downloads\scada_5.7.1_full_en\Arc\ScadaServer.zip
Install service ScadaServerService
Process completed with an error
Installation of Server application has completed with a error:
Service ScadaServerService hasn’t been installedInstall Communicator application
Installation of Communicator application has completed with a error:
Service ScadaCommService hasn’t been installedCheck the configuration of Internet Information Services (IIS)
Go to
Register ASP.NET
Installation of Agent application has completed with a error:
Service ScadaAgentService hasn’t been installedInstall Administrator application
Installation of Table Editor application has completed successfullyInstallation has completed with errors
Please restart the computerwhat cn i do?
Many thanks! -
