SGG
Viewing 15 posts - 1 through 15 (of 36 total)
  • in reply to: Send command #11724
    SGG
    Thanks Mikhail, I will use shorter timeouts…thanks also to Manjey.
    in reply to: Send command #11717
    SGG
    If the time duration to poll a device is 5seconds, and I send a command, rapid scada waits till the device is polled before executing that command.
    Is it possible for rapid scada to suspend/cancel the polling, execute the command then continue/restart the device polling?
    Regards.
    in reply to: Rapid SCADA tite text #11288
    SGG
    Worked…Thanks Kumajaya.
    in reply to: Rapid SCADA tite text #11282
    SGG
    Hello Mikhail or any one with answer, I’m using v5.8.4
    I want to change all “Rapid Scada” to “Scada” on title pages and on main body (EXCEPT ABOUT PAGE).
    which pages should i edit, i could do this easily on previous version.
    PLEASE URGENT HELP. THANKS
    in reply to: Automatic fit to screen web interface #10176
    SGG
    Worked. Thanks Mikhail.
    in reply to: Automatic fit to screen web interface #10169
    SGG
    Hello all, any response to above questions?
    in reply to: Create channel number group (V6) #10024
    SGG
    Hello manjey. Thanks for this. I did not know we could do this with current version.
    in reply to: Leading zeros #9993
    SGG
    I tried this, it works however the second is still showing. Thanks for your urgent response.
    in reply to: Leading zeros #9989
    SGG
    Hello Manjey,
    It worked perfectly…Thanks a lot, you just made my day.
    in reply to: Leading zeros #9984
    SGG
    Hello Manjey,
    I’ve tried it, not working. I’m not so good with formulas but this is what i did based on your earlier post.
    I INPUTED THIS IN FORMULA TABLE:
    double Dt(Year, Month, Day, Hours, Minute, Seconds)
    { return DateTime().ToOADate();
    AND I INPUTED THIS IN CHANNEL FORMULA;
    Dt(0,0,0,Val(6311), Val(6312), 0)
    Please guide me further.
    in reply to: Leading zeros #9978
    SGG
    The link below is a picture showing how the hours and minutes occupy two rows instead of one.
    https://drive.google.com/file/d/1lmG6N2BrYfohXd6pM-cuSkLfmNBUVOzX/view?usp=sharing
    Under T4 Availability,
    the next row = 0 hours
    the next row = 1 minutes
    can I have it as 0:1 on a single row in table view?
    in reply to: Leading zeros #9974
    SGG
    Hello Mikhail,
    concerning the above statement by Rob “Using the time example, I use a separate dynamic text element for the hours and minutes…”
    is there a better way to combine hours and minutes, and have this displayed as a single entity in table view?
    in reply to: Communication with Multiple Devices #9233
    SGG
    Hello Mikhail,
    I have a device (site A) communicating with my server using rapidgate on the 10000 port.
    i have another device (site B) that i want to integrate to communicate with the same server. i open a specific port 12345 on the server, configure my device but i get this error in the communicator log
    “2021-07-08 10:02:01 Error starting communication channel: Only one usage of each socket address (protocol/network address/port) is normally permitted”
    Both devices are set on different port.
    Device on site A (10000),
    Device on site B (12345).
    Why am i getting this error? Thanks
    in reply to: event triger #9064
    SGG
    Hello Mikhail, i have similar problems regarding event duplicates
    for every event on the list, there is a duplicate. how do i remove the duplicates?
    The images for the event, channel and channel properties is as shown.
    Event
    Channel Prop
    • This reply was modified 5 years, 5 months ago by SGG.
    in reply to: Capture Reading at a Certain Time of the Day #8719
    SGG
    Hello Mikhail,
    How do i set a channel to capture the value of another channel once every month (at the beginning of the month, between the first 15 minutes of the new month)?
