danielfernandes
ParticipantThanks Mikhail,
I understand the idea and I already got implement my solution. I am doing little error.
Regards.danielfernandes
ParticipantThanks for all support.
In really, My problem was in PlgSchBasicComp.dll because this file was blocked by windows.
Although of the other questions in this forum, I understand the problem and I found the solution.
Thanks and regards.danielfernandes
ParticipantThe log file notified that exit error in loading the plugin assembly c:\SCADA\ScadaWeb\bin\PlgSchBasicComp.dll.
https://drive.google.com/open?id=1sbwZu5B3Y4mBJkrdWpoXYW5xHM22sUjo
I found in forum that the activation of PlgSchExtraComp resolve this problem but this plugin require key.
I try require the trial key but I don’t know the compute code.danielfernandes
ParticipantI already remember of webstation, yes, and I installed the webstation.
danielfernandes
ParticipantI follow the steps of installation but I don’t remember of the Webstation.
How I can verified if the webstation is installed? And, How I can install webstation?danielfernandes
ParticipantThanks,
I already think in this solution but I don’t know working database.
But, I will try understand how create and use the database.
ParticipantYes, it is.
How I can doing?
Thanks.danielfernandes
ParticipantThe version of Scheme Editor is 5.2.3.1. I doing download of the below link.
https://rapidscada.org/download-all-files/
Where I found the video about the editor?
Do you know because I not have all components?danielfernandes
In the Scheme Editor, should I have one component with name link?
In link below, I send image of my Scheme Editor window:
ParticipantHi Mikhail,
I want to know the possibility of the implement hyperlink between text or image for another window.
I found this question with data of 2016 and I think that is exactly I need.
Is it solution already possible?
ParticipantThanks,
It is the solution for my problem.danielfernandes
ParticipantOk, I found problem in Line Stats.
I am received the message “Command execution is disable by the communication line
parameters”.
How can I doing to able this execution?danielfernandes
Participantdanielfernandes
ParticipantHello Mikhail,
Thank you for this explanation.
I already doing these steps but it did not work.
Now, I analise the log file and I understand that the tag modified with writting operation is “PLC2.Device2.Tempo Produção Atual Turno (min)” but the tag that I want write is “PLC.Device2.valor escrever”.
The tag “PLC2.Device2.Tempo Produção Atual Turno (min)” is only readding parameter.
I am not understand what I am doing wrong.
