scadarapid
ParticipantHi.
How can we send AT Command?
Can you example for me please ?Thank you so much.
scadarapid
ParticipantThank You so much.
scadarapid
ParticipantThank you so much
I use this formula and it work fine.
public double ifS(double in1,double in2,double in3)
double output = in3;
if(in1 == 0 && in2 == 1){
output = 1;
}else if(in2 == 0){
output = 0;
return output;
}scadarapid
ParticipantI finished it.
Thank you so much
scadarapid
ParticipantYes
this is my template.
https://uppic.cc/d/Kps9Formula
https://uppic.cc/v/KpsaTransfer data to the Raspberry Pi
C:\SCADA\BaseDAT
C:\SCADA\Interface
C:\SCADA\ScadaComm\Config
C:\SCADA\ScadaServer\Config except ScadaServerSvcConfig.xml
C:\SCADA\ScadaWeb\configImportant: Do not overwrite ScadaServerSvcConfig.xml. Edit it manually
then,
cd /opt/scada
sudo ./scadarestart.sh
sudo ./restart_apache.sh
sudo ./restart_xsp.shscadarapid
ParticipantI finished this point.
Thank you so much.
scadarapid
ParticipantIt works on PC but it dose not work on Raspberry Pi or I make something wrong.
scadarapid
ParticipantWhat value do you get curretnly?
Yes, it is temperature and type input register ushort.
What value do you need to display?
I need to display temperature value but I have to convert it before show on display
something like, i got 3200 so, but the value is not true so, i use formula to convert
by (3200-3000)/10 = 20 degree and show it on DashBoard.scadarapid
Participant1.example. I got the data from registers modbus and I need to show on web page but the data that I got it has to convert to become a decimal number or it dose not real value. so can I use the formula to convert my data before I show it on web.
2.if I use automatic control and I set the time, assume I set output ON at 12.00AM and OFF at 12.05AM. Can It show that on the Web page. show something like I set the output ON at 12.00AM and OFF at 12.05AM.
If it can. Please give me an suggestion.
Thank you so much.
scadarapid
ParticipantI can solve the Web Page it shows NotLoads because path /opt/scada/ScadaWed/bin which does not have .dll
scadarapid
Participantthis is picture for WebSettings.xml on Rpi
https://www.img.live/image/7bRnU6
Which line do we have to change.On the Web it shows NotLoads
https://www.img.live/image/7bRh5Ascadarapid
ParticipantHi Mikhail
I need to use DashBoard and ChartPro on Rpi.
How can we generate the computer code display for you.
Thank you so much.
scadarapid
ParticipantOther question. If i format pc or change sd card on Raspberri Pi, i can still use plugin that i already bought?
scadarapid
ParticipantNow, I already get the computer code on Raspberry Pi so, if I buy the automatic control module and other plugins, it will require internet connection to use all plugins. Because my project do not have internet connection.
Thank you so much.
scadarapid
ParticipantYou will find it in scada/ScadaServer/Log/ModAutoControl.log
My computer code on PC. it sames as my computer code on RPi. So Can i use this computer code on RPi.
CompCode.txt
