Boon Chang
ParticipantDear Mikhail,
These are the logs:
2018-11-01 15:59:36 <HSAWA1><DefaultAppPool><ACT> Request SCADA-Server state
2018-11-01 15:59:36 <HSAWA1><DefaultAppPool><ACT> Disconnect from SCADA-Server
2018-11-01 15:59:36 <HSAWA1><DefaultAppPool><ACT> Connect to SCADA-Server “localhost”
2018-11-01 16:03:20 <HSAWA1><DefaultAppPool><ACT> Logout: admin. IP address: 192.168.1.13
2018-11-01 16:03:20 <HSAWA1><DefaultAppPool><ACT> User information has been removed. IP address: 192.168.1.13. Session: xoj1xkbrtl1u0v1iggxyuf1x
2018-11-01 16:22:25 <HSAWA1><DefaultAppPool><ACT> Logout: admin. IP address: ::1
2018-11-01 16:22:26 <HSAWA1><DefaultAppPool><ACT> User information has been removed. IP address: ::1. Session: vsftgrhhzjtelo0xq4s25fvc
2018-11-01 16:22:26 <HSAWA1><DefaultAppPool><ACT> Application shutdownAlso, the log file does not have events after that last entry even though I have been using the system. I think maybe the log file requires clearing to log new events.
February 11, 2019 at 1:24 am in reply to: Elastic Report and Chart Export function through iPad #4979Boon Chang
Thank you very much. The Export option is now appearing in the Chart window as well.I think the customer is using Adobe Reader and Microsoft Excel to open the PDF and Excel files.
February 8, 2019 at 9:47 am in reply to: Elastic Report and Chart Export function through iPad #4976Boon Chang
I had made a mistake on my part. I made the changes you had mentioned to the wrong elasticrep.js file.
Right now, the Elastic Report page is fully functional when viewed using iOS device.
Thank you.Do you have any idea how to address the issue of ‘Export’ option not appearing in the Chart window when viewed using iOS device?
February 8, 2019 at 9:29 am in reply to: Elastic Report and Chart Export function through iPad #4975Boon Chang
ParticipantI see that the script is written such that the Excel and PDF formats will be disabled if iOS device is used, thus making HTML the default format.
Is there a way to make PDF the default format instead?
I tried changing the code to:
if (false && scada.utils.iOS()) {
// disable Excel and HTML formats for iOS
$(“#rbPdfFormat”).prop(“checked”, true);
$(“#rbExcelFormat”).prop(“disabled”, true);
$(“#divExcelFormat”).addClass(“disabled”);
$(“#rbHtmlFormat”).prop(“disabled”, true);
$(“#divHtmlFormat”).addClass(“disabled”);but the default checked box is still HTML.
February 7, 2019 at 1:37 am in reply to: Elastic Report and Chart Export function through iPad #4974Boon Chang
I have cleared the cache and tried on Safari and Google Chrome App on an iPhone.
iPad is not available for trying at the moment.Here are the results:
I am still unable to click on the select-box at Elastic report page.
Chart export option still unavailable.Also, the HTML format which is available for download is in a slightly different format from the original PDF format. The format is smaller than original when printed out on A4 paper.
February 1, 2019 at 11:09 am in reply to: Elastic Report and Chart Export function through iPad #4965Boon Chang
I did the change.
The following were the results:
At Elastic Report page, I am able to click on the ‘Get Report’ button and download the HTML report.
However, I am unable to click on the select-box for the formats ‘Excel’, ‘PDF’, ‘HTML’. And the HTML report was downloaded because the select-box of HTML is ticked by default.Chart still no Export option.
This is tried both in Safari and through Chrome App on iPhone.
Boon Chang
ParticipantThank you for the reply.
I will look at Scada.log again when the automatic logout occurs.
At least now I know the existence of the log file.Boon Chang
ParticipantI did the method told, and it seems I am only saving the particular page I am viewing. Saving the whole documentation would mean clicking on each individual page and pressing Ctrl+P?
I think a offline documentation is good as some environment which customers use, might not have Internet access to view the online documentation.
Boon Chang
ParticipantHow do I “save the online documentation into PDF using a browser”?
Boon Chang
I do not quite understand how this remote communicator connects to the Server of another PC as well.I have two PCs. Both has Rapid SCADA applications installed, one of them has OPC tags connected to the Rapid SCADA Communicator on it.
For both PC, I have the same setting for the Rapid SCADA Administrator (Same device name, communication line, input channel).Is it possible to obtain the tags values for the OPC tags on the other computer?
Does it have something to do with the Call number of the device? -
