Hennie_Kotze
Viewing 15 posts - 16 through 30 (of 37 total)
  • in reply to: Dynamic Picture Conditions #10005
    Hennie_Kotze
    Thanks,
    Works like a charm! 🙂
    Regards,
    in reply to: Date & Time Source and Display #9992
    Hennie_Kotze
    Thanks Mikhail,
    It works like a charm.
    Thanks for the help!
    Regards,
    in reply to: Date & Time Source and Display #9969
    Hennie_Kotze
    Thanks Manjey,
    I dont fully understand how to use that…. which channel do I use to run this formula?
    Do I create a channel to the PC so I can insert the formula in that channel? I want to use the system date and time from the PC… How do I get a channel for it?
    Regards,
    in reply to: Using KpDBImport and SQL #9962
    Hennie_Kotze
    Mikhail,
    Thank You for the response.
    Let me test it and I’ll revert back to you if I struggle.
    Regards,
    in reply to: Frame URL returns error #9945
    Hennie_Kotze
    Thanks,
    https://rapidscada.org/ is working perfectly.
    Do you have any notes on requirements for URL’s to see camera feeds? Will RTSP stream URL’s work or not?
    Regards,
    in reply to: Communicating with Kepware OPC server #8717
    Hennie_Kotze
    Hi tranduong257,
    Sorry I did not encounter any of those errors… I Whish I could be of more assistance but I cant, sorry.
    Regards,
    Hennie
    in reply to: Communicating with Kepware OPC server #8706
    Hennie_Kotze
    Hi tranduong257,
    I did manage to get it working yes, but I don’t have that project with me at the moment, I will have to create a new one if I want to remember how I did it.
    What are you struggling with?
    Regards,
    in reply to: Mobile client and Rapid SCADA #6822
    Hennie_Kotze
    Dear @arvxn01,
    In my case I had to request my service provider (Vodacom) to change my restricted APN to UN-restricted. Even while using noip, it did not work through the restricted APN.
    Hope it helps??…….
    Regards,
    Hennie_Kotze
    Thank You Guys…
    The channel 60 is defined as a REAL, but I’m actually just reading one modbus register. The value in this channel is just the decimal representation of the word, and is actually just an Integer….
    The first code ” Val(60) == 33 ? 1 : 0; ” works like a charm!!
    Thank you!!
    in reply to: Mobile client and Rapid SCADA #4827
    Hennie_Kotze
    OK,
    I had my server PC and my client PC connected on the same wifi network, thats why they could connect. My Android phone was on the cellular network’s internet, and thats why it said the address cant be reached.
    As soon as I connected my phone on the same wifi, I could connect to the server and view the webstation.
    I’m not an I.T wizzard, so can you explain how to get it working with my remote client being connected on a different network, far away?
    in reply to: Mobile client and Rapid SCADA #4826
    Hennie_Kotze
    Mikhail,
    I can enter the adress of my server on another PC connected to the internet (http://xx.xx.xx.xx/scada) and it works. I can see the project running in the browser.
    However,
    When I enter the same adress in my android phone’s browser, it says the address cant be reached.
    Is there a certain android browser version we should have?
    in reply to: localhost/scada/ #4620
    Hennie_Kotze
    In reference to my previous message:
    ” my new scheme does not want to open up. It says “The requested view does not exist or you have insufficient rights to access it.” I can open the server and demo schemes, but not my new schemes. ”
    The problem was a typo…. I did not type my scheme name correctly. Now it is working haha!
    in reply to: localhost/scada/ #4619
    Hennie_Kotze
    I eventualy got my Localhost to work…
    I had to delete the “NanoSetup” variable in my registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WAS\Parameters
    This prevented my WAS service to start up.
    Now I have a different problem…
    What could be the cause of this???
    in reply to: localhost/scada/ #4615
    Hennie_Kotze
    Ok I filled in a purchase service request for remote troubleshooting.
    in reply to: localhost/scada/ #4614
    Hennie_Kotze
    Teamviewer?
