HoracioParticipantThank you!
Rapid Scada 5.0.6.0 installed.
Extra Schema Components working properly.
HoracioParticipantThank you.
1. I can’t interpret the ScadaWeb.log nor know how to attach the file here.
3. I can choose the level component and put it in a Scheme but when I see it in Webstation I see just a white rectangle. Please see here:
http://hv-scada.dyndns.org:81/Scada use default login and password 12345
First scheme, lower right zone.
HoracioParticipantThank you for reply.
After trial key was registrated I do not see anymore the message about “Registration failed”However I still have these problems:
1. The vertical level does appear in the Scheme Components menu and allows me to
include it in a Scheme but then in Webstation I only see a gray empty
rectangle.
2. The horizontal level does not appear in the Scheme Components menu.
3. The gray gauge does appear in the Scheme menu but I can’t add it to a Scheme.
4. The colored gauge does not appear in the Components menu.I am using Windows 10, and Webstation 5.0.6.0.
Perhaps I mixed up while copying the files to the C:Scada directory.
HoracioParticipantHello
I accomplished it by adding an Input Channel to one of the devices with “Calculated real” type. In my case is channel 41.
I entered there a formula, for example: Val(615) * Val(32),
being 615 and 32 the numbers of the channels coming from different devices.
Afterwards, in Scheme Editor I put a Dynamic text indicating to show the value of input channel 41.
This worked out for input channels from different or from the same device.
Thank you for support.
HoracioParticipantThank you Mikhail.
How can I do to show in a Scheme the result of a calculation (formula) that uses values coming to Scada from different devices.Perhaps doing the calculation in an output channel of a certain device and show the output channel as dynamic text?
