HoracioParticipantHello!
(int)Cnl worked fine.
By the way, I found a “C# Online Compiler” on dotnetfiddle.net
that allows to evaluate and test C# expressions. Easy and very helpful.Thank you very much. Regards
HoracioParticipantHello,
How do I create an event that triggers on OFF-ON transition?
(Administrator version 5.5.0.0)Thank you
HoracioParticipantQuestion answered in
“Communication with Devices Configuration” in the Rapid Scada Documentation.
Regards
HoracioParticipantHello Mikhail,
I installed version 5.7.0. Windows settings are as indicated.
However, the installer issued errors.
Despite them, the version seems to work well and I could successfully follow all the steps of the video example/demo.Now I need to migrate the database configuration I was using with version 5.6.1.
Do I have to do it using the former procedure “Migrate Configuration to New Server”? Or instead,
Use the Upload and Download feature provided in version 5.0.7?I saw the indications you gave to community member “jmartins”.
Could you please explain:
“3. Download the existing configuration into the new project by Administrator.”Thank you very much.
Best regards
Horacio
HoracioParticipantThank you very much.
I replaced ScadaSchemeEditor files of 5.6.1 by the same files of 5.7.0
(ScadaSchemeEditor 5.2.3.1) and it works well.
Best regards
HoracioParticipantI mean, can I migrate to 5.7.0 with the current”Migrate Configuration” procedure?
HoracioParticipantHi Mikhail
Thank you very much for your support.
The Extra Scheme Components now appear on Webstation and do work but the Scheme Editor app. does not open.
I haven’t installed yet the Scheme Editor 5.2.3.1 from RS 5.7.0 as you indicated.Can I install just the Scheme Editor 5.2.3.1 over Rapid Scada 5.6.1? How?
Or should I install the whole 5.7.0? If yes, can I migrate my former configuration flawlessly to it?Regards
I upgraded Rapid Scada from 5.6.0 to 5.6.1 on a Win 10 PC.
Scheme Editor is 5.2.3.1
Then migrated the my old configuration to the new version on same server.
Everything works but the plugins I had before (permanent licence purchased. ExtraScheme Components, ChartPro, and Dashboard) do not work.
Then I followed the instructions on “Installation of Webstation Plugins”.
On Webstation the schemes do not open and it says: “Scheme loading failed. Try to reload Scheme”.
On Webstation – Main Menu – Plugins – Installed it says:
– PlgChartPro.dll
– PlgDashboard.dll
– PlgSchExtraComp.dllBellow each one of them it says “Deactivate” in blue.
To the right of each it says “NotLoaded” in redHow should I do to reactivate them?
HoracioParticipantPerfect! Thank you very much!
Normally (99.9%) of the times, the fonts used in Scheme appear identical in Webstation.
However, exceptionally, depending on the web browser you use, certain fonts could differ.
HoracioParticipantThank you very much! It worked ot fine.
I am trying to display Date and Time.
I set up an input channel for this type Real, formula EncodeDate(DateTime.Now) and format Date and Time. Please see image of Administrator:https://www.dropbox.com/s/mwhq8cc0vuwblzj/Trying%20to%20show%20Date%20and%20Time.docx?dl=0
I included a Dynamic Text with Scheme and assigned it to the corresponding input channel. I only get: “—“.
Am I missing something?
Thank you
HoracioParticipantClear, thank you
HoracioParticipantI click on a component and select it for editing.
Then I click on the corresponding Pointer and nothing happens.
HoracioParticipantThank you very much Mikhail.
That’s fine to average different variables.How to do to average same variable along a certain time (n previous
readings)?What does “averaging” column in Input Channels work if marked?
I saw other postings referring this subject but the matter remains unclear to me.
