September 14, 2018 at 9:19 am in reply to: Unable to send command from toggle via web interface #4250
zippoSlo
ParticipantThe question in one sentence: How to setup the output channel to connect a toggle on the web to a coil in ModBus?
On the communicator the ModBus command is working (tested on commands tab), so configuration here is OK.
September 13, 2018 at 7:13 pm in reply to: Unable to send command from toggle via web interface #4248zippoSlo
ParticipantThank you for the tip about the command, but since is a toggle switch, what should be the command parameters. I don’t know how to setup the output channel for the ModBus, do you have any example? The output channel is linket to the toggle switch.
This reply was modified 8 years ago by
zippoSlo.
September 13, 2018 at 6:48 am in reply to: Unable to send command from toggle via web interface #4237zippoSlo
ParticipantLooking at the source code I have a suspect that the problem lies in ScadaServerSvc, MainLogic.cs, procedure
public void ProcCommand(CtrlCnl ctrlCnl, Command cmd, int userID, out bool passToClients)The variable passToClients could be false at the end of the procedure, but I still can’t understand all the code (I downloaded it an hour ago).
This reply was modified 8 years, 1 month ago by
zippoSlo.
September 12, 2018 at 4:50 pm in reply to: Unable to send command from toggle via web interface #4236zippoSlo
ParticipantI would use this occasion to suggest a feature – resizable windows. I think that looking in the application log would be much easier if I could maximize the window.
I I would like to change a little bit the user interfaces and thus contribute – is there any guideline on how to partecipate in to Rapid SCADA? I should create a separate branch?
A would also say that you’re doing a great job, Rapid SCADA is great. I can’t wait to implement it in real environment (we are testing right now). We wil certanly get some of the plugins. Is there a catalog about all the plugins? Iv seen a list in the documentation, but I think there are more plugins (I fount at least one more in the forums – gauges).
September 12, 2018 at 4:38 pm in reply to: Unable to send command from toggle via web interface #4235zippoSlo
ParticipantHi!
Communication log: in the communication log there is no entry about this command (I also checked detailed log).
Application log on web server:
2018-09-12 17:36:34 <CCNSCADADEV><SYSTEM><ACT> Command 0x06 (command) is received from the client 127.0.0.1
2018-09-12 17:36:34 <CCNSCADADEV><SYSTEM><ACT> Command: out channel = 1, user ID = 11
2018-09-12 17:36:34 <CCNSCADADEV><SYSTEM><ACT> Command is canceledWhy the command is cancelled?
zippoSlo
ParticipantI switched to ModBus and it works. Having still some problems, but in 2 days I managed to make it work 🙂
It seems ModBus is a good solution for our purposes.
zippoSlo
ParticipantI will contact the OPC server manufacturer and ask about UA and the will to solve the problem together.
zippoSlo
ParticipantHi!
I have a similar issue connecting to CyBro OPC 3.0.6 server.
I can’t connect with Rapid SCADA (E_NETWORK_ERROR). I also tried the test client you provided and it hangs during connection (after I select an OPC server from the list and click Connect). But I can connect with the Matrikon OPC Explorer 5.1.3.0 and works fine.
Running all on same machine.
Help!
