rsepulve
ParticipantHi Mikhail,
This is Rodrigo Sepulveda, from Chile.
I have an issue.I have the folowing payload from UG56 Milesight Lora gateway.
{“adc_1”: 4, “adc_2”: 4, “applicationID”: 1, “devEUI”: “24e124445d182905”,
“deviceName”: “VDBT-TDC-03”, “gpio_counter_1”: 4018, “gpio_input_2”: 0,
“gpio_input_3”: 0, “gpio_input_4”: 1, “gpio_output_1”: 0, “gpio_output_2”: 0,
“modbus_chn_2_alarm”: 1}but the original from field, from Milesight UC300 device is:
{“adc_1”: 4, “adc_2”: 4, “gpio_counter_1”: 4018, “gpio_input_2”: 0, “gpio_input_3”: 0, “gpio_input_4”: 1, “gpio_output_1”: 0, “gpio_output_2”: 0,
“modbus_chn_2_alarm”: 1}But, I can´t take off this 3 elements thats UG56 gateways add:
“applicationID”: 1, “devEUI”: “24e124445d182905”, “deviceName”: “VDBT-TDC-03”
This cause an error in MQTT communications lines.
2024-12-20 11:31:38 Receive biocorneche/vdbt/pla/gbtes/24e124445d183109/up = {“adc_1″:4,”adc_2”:0…
Subscribed devices: 3
Hello from JS. Topic: biocorneche/vdbt/pla/gbtes/24e124445d183109/up
Error: The input string ’24e124445d183109′ was not in a correct format.How can I fix or ignore those strings?
Thanks.rsepulve
ParticipantThanks Mikhail,
I’ll try.rsepulve
ParticipantHi Mikhaeil,
Sorry, I reffer to the communicator side looking to GSM RTU.
for example I have 2 RTUs.
One with Modbus RTU and other with Modbus TCP.
You talk about if the RTU start communication, don´t matter the remote IP addres, how I have to configure the channel setting type tcp cliente, tcp master, in properties, master, Slave, connection individual, shared, etc.
That is confused to me.
I´ve put in GSM RTU, the public address and TCP port 502.
In the router I´ve forwarded the 502 port to internal IP addres of Communicator and SCADA server.
I´ve looked in the ethernet port that the data is coming to Server, but I confused to manage the response or polling from server to Remote GSM RTU, If I choose TCP, I need to put a remote IP address, wich, public GSM RTU or private GSM RTU, or what is the other config that doesn´t need the remote IP address?Thanks for your response and time.
rsepulve
What should be the right configuration in communicator for Modbus TCP protocol?
Thanks.rsepulve
ParticipantHi Pieter,
Can you explain how to connect remote communicator to Server and configure the data variables?.
In remote communicator I´ve puted Server, remote public IP and Port.
But how have I to create and configure a new connection in Local Server?Thanks.
rsepulve
Thanks for the information, but my problem is IP addressing.
For server no problem,Use a public IP and Nat the 502 TCP port to internal IP address. But, what IP addres I have to put in coomunication settings dor slave devie? Private or Public of remote GSM RTU?Thanks.
