josesanchez
  • in reply to: Language pack issue Spanish #3647
    josesanchez
    Hello Mikhail,
    I will use Notepad++ and let you know any information. I will try to check them first by myself.
    Thanks,
    José Sánchez
    in reply to: Language pack issue Spanish #3641
    josesanchez
    Hello Mikhail,
    I did exactly what you told me (to copy the en-GB file, translate and save), but it didn’t work. When I start the Scheme Editor application it runs perfectly with no errors but in English. It seems that it doesn’t take the es-LA file at all.
    Also I wanted to make some changes in other files, like for example ScadaAdmin.es-LA.xml, because it has some grammatical and syntaxis errors. But when I save the file with the changes and run the application it pulls out an error and launch the application (in this case the Admin) in Russian.
    I’m just changing the sentences and nothing else and then save the file but it doesn’t work.
    When I open the .xml files it opens the WordPad software, in which I make the changes. This information in case you wanted to know.
    The solution I’m thinking off, is that I can send you all the files in Spanish and then you have a check and add the in the Language Pack properly.
    Waiting for a response
    José Sánchez
    in reply to: Language pack issue Spanish #3633
    josesanchez
    Hello Mikhail,
    Thanks for solving the problem with the Communicator application. As for the Scheme Editor application I will do the first option you said.
    Once I have a tested and fully functional .xml I will send you the file to help the community
    Thanks,
    José Sánchez
    in reply to: Language pack issue Spanish #3626
    josesanchez
    Greetings,
    I downloaded the updated version as you said and the problems I mentioned in the last post were solved. Now the Administrator, Table Editor, Server and Webstation applications are in Spanish and working perfectly as I saw.
    But now I have two new problems, one for the Communicator application and the other for the Scheme Editor application.
    Communicator application error:
    “Error loading dictionaries from file C:\SCADA\ScadaComm\Lang\ScadaComm.es-LA.xml: ‘<‘is an unexpected token. The expected token is ‘>’. Line 238, position 2.”
    After clicking “OK” the Communicator application opens in Russian language, but apparently everything works perfectly, just obviusly in Russian so I don’t understand.
    I checked in the GitHub you send me the specified line and I saw that this line has a space before the sentence. The line before also doesn’t have the ‘>’ symbol after the sentence. I’m not a programmer so I’m not sure if that affects to the problem directly. I’m just trying to do my best to help the community and have a better SCADA solution.
    Scheme Editor error:
    ““Excepción de Unhandled:
    Filter string you provided is not valid. The filter string must contain a description of the filter,followed by the vertical bar (|) and the filter pattern. The strings for different filtering options must also be separated by vertical bars. Example: “Text files (*.txt)|*.txt|All files (*.*)|*.*”
    After clicking the “OK” Button the Scheme Editor application opens in Spanish language (with some components and objects in English), but the website for making the editions to a scheme doesn’t open automatically, as it used to happen in English and Russian language. Even when I click in “Archivo -> Open browser” (“File -> Open browser”) it doesn’t open and launch the following error:
    “Archivo C:\SCADA\ScadaSchemeEditor\Web\plugins\SchemeEditor\editor.html no encontrado”
    Which means that the file C:\SCADA\ScadaSchemeEditor\Web\plugins\SchemeEditor\editor.html has not been founded.
    I’m sorry for the long post, and for being insistent by installing the Spanish language, but hope that with this we can help all the Spanish community to install the Rapid Scada in this language without any problems.
    Also I’m currently doing my Thesis in the Universidad Rafael Urdaneta in Maracaibo, Venezuela. For this reason it would be perfect and really helpful if I can use the Rapid Scada in Spanish language without any problems.
    Waiting for a response,
    José Sánchez
    in reply to: Language pack issue Spanish #3603
    josesanchez
    Greetings,
    Thanks for the help, I did the change manually, but now when I restart the applications it appears the following error:
    “Error loading dictionaries from file C:\SCADA\ScadaAdmin\Lang\ScadaData.es-LA.xml: Data at the root level is invalid. Line 1, position 1.”
    And the next one too:
    “Error loading dictionaries from file C:\SCADA\ScadaAdmin\Lang\ScadaAdmin.es-LA.xml: Data at the root level is invalid. Line 1, position 1.”
    I did check that all the files had the proper name but still can’t change the language of the applications
    Hope we can solve this problem
    José Sánchez
