jeff
ParticipantThank you very much.
Hopes it work. Thanks again.jeff
ParticipantSorry for late reply and thanks for your explanation. I get it and it works. Thank you.
Can I do it for 2 conditions?jeff
Can you explain how the formula work as you shown in (example: Val(1) < Val(2) ? 0 : 1)?
How to set condition in rapid scada scheme for the led indicator regarding to the formula above?Thank you.
jeff
ParticipantNoted with thanks.
jeff
ParticipantHi Mikhail,
Excel is not a good data source, so what is your suggested format file if want to receive data from the 3rd party database?
Hi Manjey73,
Thank you for your information. I will try it.
Jeff
jeff
Can Excel data act as an input to Rapid Scada?
jeff
ParticipantThank you very much for your help.
jeff
I had executed the svc_install.bat from the command line as administrator above is the screenshot.
It shows “The transacted install has completed.
The installation failed, and the rollback has been performed.”
Is this expected?I downloaded and run the SetCulture utility on the command line, here is the screenshot.
It shows “Please type a culture as an argument.”, may I know what is the parameter for the argument?
Thanks in advanced.
This reply was modified 8 years, 7 months ago by
jeff.
jeff
ParticipantSorry I can’t find C:\SCADA\ScadaAdmin\ScadaAdmin.err, and actually I also can’t close the application, it will show the problem that I show before this.
jeff
ParticipantI am using windows 7 professional with 64-bit operating system.
jeff
I tried it many times, I not sure is that the software problem or what because it will come out the below as the attached image.
jeff
ParticipantHi Mikhail, my default windows language is english.
I tried the 2 methods you suggested, I installed the set culture but it can’t work. And for the setting side I can’t find the english.
Please advise.
jeff.
jeff
ParticipantThank you very much. I can use rapid scada now. but when I open the SCADA administrator, I cant understand the language and not same with the video I watched.
Please advise. Thank you.
jeff
Participantjeff
Participanthttp://tinypic.com/r/1zl3m09/9
jeff.
