leon
ParticipantNew question
Can I define different buttons using different formulas in the same Number (19)?
https://imgur.com/a/K6Gfpt1Can I omit the password?
https://imgur.com/NGl3BMG-
This reply was modified 8 years, 2 months ago by
leon.
leon
ParticipantSystem architecture
https://imgur.com/a/iqtz0F5I found that it can be to on
Val(n)* 1-
leon.
leon
ParticipantHi Mikhail
Thank you very much for your demonstration.
I have read Article about using formulas because I don’t understand the rules of formula.
Need some simple arithmetic examples to reference.-
leon.
leon
ParticipantHi manjey73
Thank you very much, so I can understand why it is 256.
https://imgur.com/a/M6i0G0Eleon
ParticipantHi
Can you demonstrate the formula settings?
Let output channel on or off or reverse settings.Is there an article that can learn Formulas?
I have seen Using Formulas(roadmap) still don’t know how to use it.leon
Participantleon
ParticipantInput channel command type switching counter, formula is Cnl*200/65536 – 40
If Input channel command type real will overflow.
leon.
leon
Participanthi
I have not set the formula.
From the scada send command or from the plc send command,
Scada communication is normal.But showing a problem through the input channel
I sent 0 show 1
I sent 1 is normal
I made 2 shows 3
I sent 3 is normal
I made 4 shows 5
and many more…
(Please refer to the picture above)Sorry, I didn’t explain it very clearly.
leon
Participanthi Mikhail
Rapid scada is great.
I am very happy that I can help.leon
Participantleon
ParticipantZOOM IN is normal
ZOOM OUT is abnormalleon
Participanthi
From PLC or SCADA Send the command (Decimal) 0.2.4.6.8~…
Scada shows 1.3.5.7.9~…
I hope that Scada is also showing 0.2.4.6.8~…
Is it related to formula?leon
Participanthi
Provide Interface to you?
from emailleon
Participanthi
I have a problem. SchemeEditor-Toggle resolution is abnormal.
https://imgur.com/a/3pE58qZ -
