New Web App Idea?
Forum Home Forums Uncategorized Issues New Web App Idea?
Viewing 15 posts - 1 through 15 (of 48 total)
  • #1191
    Hi All,
    Imagine I can display a custom window below the main view pane. What useful information would you show in such window?
    Ideas are welcome 🙂
    #1194
    inpelsa
    without seeing main view panel… not sure. any screenshots?
    #1195
    Instead of “Ошибка сервера в приложении ‘/Scada5′”
    #1200
    Washu Hakubi
    Hmm in the place of the event window? Or alongside the event window?
    #1201
    Washu Hakubi
    In any case a minimize button for the new window if there is one and a minimize button for the event window would be nice.
    Edit: An automatic display along with the minimize button would be awesome.
    For example, if all the event have been checked i have an option to hide the event window, but the event window will automatic open again when a new event happens.
    Just and idea not sure if it’s is even possible to do it, never used iframes before.
    • This reply was modified 10 years, 3 months ago by Washu Hakubi.
    #1203
    Custom Data window. Events closes when another window is shown.
    It exists – the gray circle with arrow.
    Notifications like Skype would be nice, but not in beta version.
    #1220
    maksimred
    I would really like to see the “oshibka servera….” window minimized then when I click on a temperature or some value then the minimized window will expand like u have it in the screenshot and trend graph loads to show the recorded events.
    #1253
    Washu Hakubi
    Hmm maybe a custom event window itself.
    Atm the event window is just that table with for the operator can sometimes be a little vague. If it was possible to create a random event messages to be displayed. Like for example i have this door that can’t stay open for more then 5 minutes for who know what reason, the i get this event that the door stayed open for that time, i can put a String like “The door number X is open for 5 minutes please check if everything is right and close the door”.
    Or for even more crucial events like the undefined events. Like if i have this device that have 10 tags on it and for a reason the device go offline, i will have 10 undefined events for those tag, the operator will just look at those events and be like “OK now what?”, and then we could put a string that say something around the lines “The connection to the device X was lost, please check if the device is powered and the cable connections to the server are OK, if the error persist contact the IT department”
    P.S: For the first option the Automatic Control Module (ACM) might be required. Did not play with ACM until now so not sure what it can do.
    #1255
    This idea requires development an additional module for SCADA-Server. It’s interesting.
    You can create a calculated channel to determine the state of connection instead of using “undefined” events.
    #1281
    The prototype is here http://demo.rapidscada.net/
    Login and password as usual: admin / 12345
    #1282
    inpelsa
    too early to give a good opinion (through is quite useable and fast), too many things not JET implemented.
    JET => YET
    Unless you are going to implement it too fast 🙂
    #1283
    Try it on your PC, phones, etc., please. If there are some bugs, let me know. It is a good time to fix them.
    P.S. IE is not supported. Chrome, Firefox and Edge are OK 🙂
    #1284
    Washu Hakubi
    Seems really nice, but hard to say what is a bug since idk what is already implemented and what is not.
    Questions:
    1- What happened to the copyright on the footer, there is nothing on the login screen or the main applications itself, is it only going to be in the about page?
    2- Where will the event iframe be, bellow the main area as it is now?
    3- What will the Logged Users button/link do? The “a” tag id “hlMainUser” inside the div id “divMainUserMenu”, atm is sending to page 404 (page not found).
    4- This new webinterface is using ASP.NET 4.5 or is it using ASP.NET 5? If its 4.5 can i run all its functions on a Linux Server with Apache and mod_Mono or is there some limitations?
    Bugs:
    1- On mobile, when I’m on landscape, the collapse menu button on the bottom left of the screen desapear and there is no way to roll down. Here is a screenshot from the device: http://imgur.com/Z40M2yW
    The device is Android 4.4.2 kitkat, model LG-D100F, 3.0 inches screen.
    #1288
    Write here if you think that the web app behaves weird or unexpected ))
    1. I think the logo and the title Rapid SCADA are enough. May be copyright will be in the about page. I’m not sure, should I write “copyright” for the open source software or not.
    2. As shown in the screenshot above.
    3. Information about the user. May be there will be user rights info. It is not implemented for now.
    4. It uses .NET 4+.
    .NET 5 is not widely supported by hosting providers.
    I think it will work on Apache + mod_mono, but test this configuration please.
    #1290
    inpelsa
    On my lenovo a820 with a forged ROM it doesn’t work at all.
    Web is shown but without views list. No views… no graph…
    4.4.2 with vMS V rom
    Juat as a note in case it happens with other devices, not worth to debug.
