Strange behavior in the communicator
Forum Home › Forums › Communicating with Devices › Strange behavior in the communicator
  • #7253
    jeeslo
    Hi! Recently I discovered something I don’t know if it is a software error or some bad configuration, it turns out that the communicator stopped but I noticed that I can still see that the device label still showed me frozen data, the problem is that in the scheme everything seemed normal. But I had the communication shutdown, even the network cable was disconnected, could you help me please.
    Comunicator Frezzer
    Link imagen https://ibb.co/S6fzN9zComunicator Frezzer
    • This topic was modified 6 years, 1 month ago by jeeslo.
    #7258
    Please describe the expected behavior of the software to understand the question.
    #7269
    jeeslo
    Hi Mikhail!
    Of course I describe better … for example in the communicator I have a connection to the device and its value received in 1 for some reason my network connection fails. This value 1 should change — null because there is no communication, it should not show a value. What happens is that if communication is lost for any reason, the values remain active or frozen since their last status reception.
    thank you
    #7270
    jeeslo
    Hello
    The very strange truth happened after updating the version, I did so many things and I did not document it, sorry, between restarting the pc and some activating and deactivating the line I can recover and operate normally as always.
    If this happens again I will keep you informed
    Thank you so much
    #7272
    If a connection between a device and Communicator is broken, you will get empty values after next polling attempt.
    If a connection between Communicator and Server fails, you will get empty values after a certain period of time.
