Server Room Demo
Forum Home › Forums › Understanding the Software › Server Room Demo
  • #4558
    Peter
    Hello Rapid Scada Team,
    I got the software running, including modbus. The Connection is working. As I see, all is fine. 🙂
    When I login in to the web-interface and look at the server room example, i see some strange values. The all t are showing -40 degree.
    Compared to the Live Demo example on your website, I miss the buttons to :
    Power 1:On
    Power 2:Off
    on my installation. What is wrong?
    Do you need Screenshots?
    Another question:
    How can I include my own sub-webpage in this. (like an 2nd about)
    Thanky,
    Peter
    Background story:
    Every Year, we make an event called Capture the Flag (CTF).
    We set up different systems and services with obvious security problems. The CTF participants have to scann and detect the vulnerabilities and find some flags (text code like: cyber_yourockedit). I like to create a system with a vulnerable modbus service. Best would be a remote controllable scenario, so the participants can influence each other. 🙂
    Furthermore, i like to write another flag in the a sub-webpage of the rapid scada. So I need to understand the refreshing process of the loaded data of the web-server and the input files.
    Thanks for your help.
    #4564
    Because of the formulas applied to the appropriate input channels. You can see the formulas if open the Input channels table in Administrator.
    You can place a new html file in C:\SCADA\ScadaWeb\plugins\
    and specify it in the Interface table in the Path column.
    Other way, is using Dashboard plugin.
    Your story is exciting ))
    #4568
    Peter
    I’m sorry to bother you again. I need it more specific.
    What do you mean with: specify it in the Interface table in the Path column.
    I didn’t find it.
    #4570
    Open Administrator, double click the Interface table in the tree view.
    If you don’t see the Path column, please place a link to a screenshot here.
    #4572
    Peter
    Perfect! Thankys. It works. 😀 *Happy*
    #4575
    Good 🙂
