Remote Procedure Call (RPC)
Forum Home › Forums › Communicating with Devices › Remote Procedure Call (RPC)
  • #6432
    kirjono mudiarto
    I have several devices communicating using Modbus protocol and I have sucessfully communicated with them except for one that communicates with the Remote Procedure Call (RPC) protocol and it said that the data format is JSON.
    How can I communicate with RPC through rapidscada?
    Here also I attach the link to the datasheet/manual.
    http://files.sma.de/dl/2585/SWebBoxRPC-BA-en-14.pdf
    kirjono
    #6435
    You should try SMA OPC SERVER.
    Other option is creating a native driver for Rapid SCADA which interacts with Sunny Webbox directly.
    #6438
    kirjono mudiarto
    Could you guide me step by step how to implement this OPC Server, and also i want to integrate with other devices like PLC, meter, MV Switchgear?
    #6440
    OPC server is a software developed by a manufacturer of controller.
    First, you should download, install it and get data from a device.
    If you need support in this process, you should ask developers of OPC server for help.
    #6441
    After you do the above, next step is integrating OPC server with SCADA.
    #6444
    kirjono mudiarto
    I did not find the OPC server software, it looks like the manufacturer no longer supports it. What about the other option as you said creating native drivers?
    #6445
    It’s possible to develop a native driver, but may be expensive.
    Have you directly asked the manufacturer about the OPC?
